DRIER IS NOT RUNNING - Washing Machines
    Sergeant:
  • 270 Answers
It lacks proper running shoes.
On the other hand if we had a model, how long you had it, we might be alittle more helpful.
Still... the dryer is a simple machine, it has a motor and a belt and a drum.
If the motor is not running, it might be broken or it may be an electrical problem. If the motor turns but the drum does not, the belt might be broken.
Good luck.
Posted on Sep 27, 2010
Samsung Fridge freezer - switches on fine. reaches correct temps .. turns off .. and then dont come back on again HELP HELP HELP
Hallo
It could be the compressor winding's starting to cause it not to start up after running for a while because the drier is blocked and when the drier is blocked it will start running in a vacuum causing it to spark(burn) on the inside of the compressor or could still be in a vacuum and causes it to spark when it should start.
Regards
Jun 22, 2016 | Samsung Refrigerators
Bosch advantixx washer drier drier only runs 5 mins then switches off
The likely answer is the motor is overheating and the auto cut-off switch activates. If you wait a while it will then start up and repeat.
The answer will probably have to be a replacement motor, but a qulified engineer may find he can clean up the motor contacts and get it running - but that may cost same or more than a new motor!
Nov 18, 2015 | Bosch Washing Machines
My 65 corvair 110 won't start up , when it was running fine hours ago before I washe engine
Dry out all the ignition parts, distributor cap (inside and out) plug wires and caps including coil wire with a hair drier or heat gun on low. If no hair drier is not available dry the best you can and give a light spray with WD40.
May 02, 2015 | Cars & Trucks
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
I have a magic chef model ye205k electric clothes drier, which has been a really good appliance. my wife started it earlier today, and walked away. about 10 minutes later, she noticed that the drier was...
the motor in a tumble dryer in a dryer is a capacitor start induction motor.you need to call a serviceman to check both the capacitor and motor.
Nov 22, 2009 | Dryers
Drier keeps shutting down.
I had the same problem, they wear out in the rear bearing slot and drag on the front slides, So I bought Sears heavy duty model and it was was running better than ever until my wife took it away when she left me. Hope this helps
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
