Question about Vinotheque Whisperkool 8000 Wine Cooling Unit (Max Room Size = 2000 cu ft)
Unit runs for a period of time, then it causes the circuit breaker to blow
  • 43,501 Answers
The compressor has gone bad... it probably will not be worth replacing it...a new unit will be cheaper...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 27, 2010
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Oct 31, 2012 | Electrical Supplies
My model # AD70USR0 Whirlpool dehumidifer cycles on and off. It may have been hit when I had a lightning strike. It is like the compressor is frozen as it tries to run, but just cycles on and off. It...
The problem with ligtning strikes is it impossible to determine what damage has been done without first visually inspecting all the components and then testing them to make sure they are intact.
If your blowing circuit breakers then the compressor is overloading the system while trying to start, There is a big current draw when they start up.
The compressor has an internal cutoff if pressures aren't met or it gets too hot and if one of these is bad then that could cause the issue.
There also could be a Defective start relay, start capacitor, run capacitor, transformer or compressor. The thermostat or humidity control may aslo be bad causing this issue, try adjusting it up to where it will run for long periods of time to see if it starts and stays running.
Do you have any way of testing the electrical components?
Aug 30, 2011 | Whirlpool Refrigerators
I have a whirlpool central air conditioning and the condenser stoped working. what could I expect it to be?
When you say the 'condenser' stopped running - I'm 'assuming' you are talking about the outside unit, and I'm also 'assuming' that when you say it stopped running you mean 'nothing' runs on the outside unit - fan motor OR compressor. The fan motor will drown out the compressor running noise which is a 'low rumbling' sound - often not heard by the layman because of the noise the fan motor puts out.
Assuming you are talking about the outside unit and 'nothing' is running either fan motor or compressor then you might be 'in luck.' Because the most likely reason for the outside unit to be totally off will be a 'blown fuse' or a 'tripped breaker.' The good news is that in 'hot weather,' especially the kind of hot weather that has been present this summer (especially in the south) - blowing a fuse or tripping a breaker is not necessarily an expensive repair.
Indeed, it's not uncommon for a AC unit to blow a fuse (or trip a breaker) on occasion, although it must be noted that doing so is also is sign on something seriously wrong with your AC, i.e. a fan motor breaking down electrically or even a Compressor, both being expensive items to replace.
But, as I said, it's not uncommon for a fuse to blow once in awhile.
I would check my fuses (and breaker) and see if this is what has happened.
If you have fuses (usually located outside close to the condenser) and have no way to check them (you check them with a ohm meter looking for continuity) - then just 'replace' them with new ones. Note: always put 'time delay/dual element' fuses back in - even if the ones that are in there now are 'one time' fuses. 'Time delay' fuses do just what they say they will do - (they hold for just a second or two during that initial start up (of the compressor) without blowing).
If a blown fuse/tripped breaker is your problem then "most" of the time the AC will run ok and you will not have any more problems.
However, if after replacing the fuses and turning the AC back on - the fuse(s) blows instantly, or a short period thereafter (say a few minutes or an hour) then you probably have a problem that is causing it - i.e. the fan motor or compressor is going bad.
Note: one thing that you can fix that might be causing the fuse to blow is a dirty condenser. So, check the condenser coil (think of it like a car's radiator). It 'must' be clean to run properly and when it gets 'really dirty and clogged with dirt it will cause high head pressure and can cause the unit to blow fuses and trip breakers.
Good Luck!
Aug 10, 2011 | Whirlpool Heating & Cooling
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Circuit breaker trips out when all lights on the circuit are off.
You have a dangerous situation there. If the breaker is tripping like that and espec. if you have no load on it then there is an intermittent short that is happening in the circuit somewhere. The hot wire is shoeting to the neutral or ground wires at some time... This will cause a fire if you leave it and do not find the cause. The best fix would be to rewire the whole circuit if you can not find the cause of the short. To identify the short look for a black spot in the wiring some wher. the arc from the short will cause a burn mark when it happens..
Good luck and be careful!!
Heatman101
Feb 08, 2010 | Electrical Supplies
Frigidaire Laundry center blows circuit when w/d run at same time
Okay, here's the best I can do from this distance.
The combo unit is on a 30-amp, 220-volt circuit. One cord supplies both washer and dryer.
The breaker does not trip until the washer motor starts running simultaneous with the dryer drying.
My guess is that (if the combo unit is connected correclty to the one supply cord) the dryer motor runs off the 110 volt supplied by the red/white wires & the washer motor runs off the other 110 volt leg, black/white (could be vice-versa, but that's irrelevant).
The dryer heating element runs off the 220 volt supplied by the red/black wires.
There are two most likely causes (but not the only possibilities):
- The breaker is bad -- could just be oxidation on the breaker contacts in the bteaker box -- I havae seen this conditon -- small amounts of oxidation can cause the breaker to overheat and trip -- of course, the more current the load draws the hotter the breaker gets.
- One of the motors (washer or dryer) is beginnig to fail (windings beginning to short) and drawing more than rated current which is overloading the breaker.
Checking thes two theories requires some not-so-standard equipment, and some more-than-handyman expertise. And if neither of these theories pans out, the troubleshooting gets more complicated.
So, to address your original question, "Can I fix it myself, or should I hire someone?, I would say you should hire someone. This wirite-up may give them a head start.
Let me know if you have any questions.
Charlie
P.S.
A third possibility (only possible if this tripping condition ahs existed from the beginnig of the w/d installation) is that the power cord is connected to the unit such that both motors are powered by the same 110 volt leg. Not being there to assess this, I can't say how likely this is, but it's a long shot for sure.
May 27, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
15 amp fuse blows when AC breakers are closed at power source
hire an electrician. period you may need to have a larger wire and larger breaker installed..
do not attempt to do it yourself unless you are a licensed journeyman electrician.. the problem is prolly fairly serious.
make sure if wire and breaker are replaced that the person who does it pulls a permit period..
Apr 30, 2009 | Coleman Propane Forced Air Heater...
Refrigerators Logo
97 people viewed this question
Top Vinotheque Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vinotheque Refrigerator Expert? Answer questions, earn points and help others
