Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer jam I placed a 4x6 blank photo card in the lower paper tray of my canon mp 780 printer that caused a paper jam. I cannot get the card out of the printer either fom the front or the back of the printer. Help.
  • Les Reeves May 23, 2008
    cannot reach or even see paper.
    cannot see or reach paper
    Sergeant:
    Champion:
  • 304 Answers
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
Posted on May 23, 2008
  • Elizabeth Krijt
    Elizabeth Krijt May 23, 2008
    well in that case, you need someone to disassemble the printer or need someone who have a knowledge opening & troubleshooting printer..
  • Canon Master
  • 13,433 Answers
You can get the user manual with instructions on clearing a paper jam from this page
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=10444#DownloadDetailAct
Il post you instructions in a moment if you need them.
  • Ekse May 23, 2008
    Read this page for detailed instructions on clearing a paper jam in your spesific printer
    http://koti.mbnet.fi/exuli/Chap12_US.htm
  • Ekse May 23, 2008
    It might be difficult in that case, might I suggest you take it to a professional to have it taken apart and the paper removed?
    I dont have instuctions for takeing the printer apart.
    Genius:
  • 1,142 Answers
Did you check for any piece left in the printer which is causing the Jam
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing onto photo paper from mac g4 computer
I put the 4x6 in the bottom cassette. I place it with the shiny side down. Landscape is when the 6" length is front to back in the tray.
I use the cassette exclusively for 4x6 and use the back tray for all else. It works great.
Apr 20, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
