Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
I get only one chanel
My 2003 Sony recently went on the fritz. I can't receive any cable chanels other than chanel 39 even when I push any button on the remove. To boot, the reception is not clear at all.
I've tested the cable with other TVs and all other tests show the cable line to be ok.
What could be the problem?
DB in WI
  • 58 Answers
Go to the menu and select channel set up
select cable
select scan
This will usually solve it
Otherwise it may be the tuner , CPU or a cold solder joint or open trace on the clock sig.
Thanks Guy
Posted on May 27, 2008
How do i set the chanel to 3 so that i can hook up cable with out a remote
Most sets it is impossible and will skip channel 3 and input. You will need to buy a cheap universal remote.
Feb 27, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV GETS NO CABLE CHANLE BUT WILL PLAY DVDS
same thing happened to a tv i let my parents use.. They said it quit working and were gonna throw it out.When i went over there, and turned it on. i found that some one hit the video button on the remote, and the screen went black and there was no sound.. It was just a black screen.even though it was on.when i showed them, they just looked at each other, then blamed the grand kids.
Dec 15, 2011 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
My sony trinitron tv is off the normal chanel 3 an I cant get it back on there. I have AT&T CABLE my son touch the tv an switch the chanel. My problem is I dont have the orginal remote. An I have...
Hi, if you have a "menu" button on the front of the tv go into the menu & "auto-program" the channels, if your set does not have the menu button on the front you will have to call a local tv shop with the model number of your tv and they can order you one, gl, video-tek
May 18, 2009 | Sony Televison & Video
How do I receive anolog stations on my VIZIO tv
you need to go into the menue, under setup and chanels, do the auto program, it will memorise all the chanels that you can get, analog, and digital, after that, just type in an analog chanel, if it goes to a digital chanel, hit the chanel down button
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tivo not working correctly
Cable chanels an dtv chanels are not the same
Oct 28, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
