Question about Smeg WM16AAA Front Load Washer
Drum The drum of my machine is knocking against the machine - how do I fix this?
  • Codfish1 May 23, 2008
    The drum seems to be detached from the main shaft, it rotates but just flops around
Stick some neoprene-type patches on the inside of the body either side of the drum- you'll see where from the wear marks. Use super-glue to ensure lasting satisfaction.
Posted on Apr 10, 2009
2 Suggested Answers
SOURCE: banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
Posted on Feb 01, 2010
My defy automaid 600 front load washing machines barrel seems to be loose and is knocking against something. How to I inspect it to see what is wrong.
Hi, it could be a few things either drum bearings are needing renewed or drum tension / shocker is not functioning properly.
Jan 25, 2016 | Washing Machines
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
Ultima extra wma64 drum is loose and rattling
Your bearings have broken up in the drum. This is a very difficult DIY fix since it involves stripping the front from the machine, taking out the drup assembly, splitting it, knocking the centre spindle free and then knocking out the machine pressed bearings and replacing them.
It CAN be done by an ameture. I do it occasionally when I am repairing machines and I constantly moan about the fact that I really need to build or buy a tool to knock the bearing out. Despite the fact that the new bearings will cost about £20 ($30) ish, this is a nightmare job. Your local repair man will probably come and fit a refurbished drum for you (Then take yours away and refurbish that for his stock when he has time).
If you have never done anything like this, my best advice is that this is NOT the time to start!
Get a quote, then decide if you want the machine repaired, or to go buy a new one I'm afraid
Jun 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Washing machine works but occasionally makes noise occasionally at end of cycle, when spinning etc. I suspect a missing sock may have found it's way through the gap and is in the drum housing, out...
Clothing cannot get into the drum housing. Noises which occur during the spin cycle suggest that the drum is being thrown of balance during the spin cycle. A possible cause of this is that the bracket which holds the drum to the spindle is partially broken. This bracket consists of 3 or 4 arms and eventually one or more arms will crack and break (this is a result of the interaction between the steel drum, aluminium bracket and electricty, which weakens aluminium over a period of time). If the machine is not examined and repaired, then the drum noise will get worse and the drum will start to knock & rub against other parts, especially the water heating element and this will result in a more costly repair.
May 19, 2011 | Washing Machines
Loud knocking and a loose inside aluminum drum.
One or more of your tub supports is broken. Unfortunately there is no cheap fix but wiil be cheaper than a new machine.
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Banging noise on spin cycle
May 09, 2009 | Washing Machines
The spin cycle is making a knocking noise and we suspect that because the drum is moving when you touch it that the drum needs replacing. That possible an arm on the spinner is broken. The machine is just...
hello, have you checked to make sure your washing machine is level ? ,and yes the arm is a possability thay also help support your drum. for the cost of labor i agree far cheaper and not a hard fix for the do it yourselfer. it does'nt sound like you need a neew drum just need to fix the one you got.
Mar 31, 2009 | Washing Machines
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Knocking noise on spinning
it may cause more damage to other damper/suspension components if used. confirm exact fault- also check concrete weights for security.
Feb 16, 2008 | Indesit W 123 Front Load Washer
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
122 people viewed this question
Top Smeg Washing Machines Experts
Chris Hall
Chris Hall
William Dehn
William Dehn
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
