Question about Peg Perego Pliko Hood Stroller
Pliko Back rest detached
My Pliko Back rest detached when my toddler leaned over it while standing on the back. Now is lying flat, how can I reattach it?
  • oliverale Jul 28, 2008
    Hi! The problem is bigger than that.
    The piece that makes that handle work broke. The one that makes it work so you can put the backrest in different positions.
If I understand your problem correctly, all you need to do is reach behind the seat and there should be a semi-round handle with Peg Perego written on it. Pull it out, and adjust the seat back upright while pulling the handle. Hope that helps!
Posted on Jun 05, 2008
What causes back tire lean to the right?
does the bike handle correctly? Are your swing arm bushings worn or wheel bearings bad or is it adjusted improperly?
Jul 21, 2014 | 2006 Harley Davidson FLHRS Road King...
Tv is wobbly and leans slighty to the right I think i need a new stand
Make sure all the screws on the back holding the stand to the tv are tight.
If you can, lay the tv down gently flat on its back and look at the bottom of the base to see if you are missing any little rubber pads. If you are, just glue something rubber-like of equal size / shape / thickness in its place, or remove the rest of the rubber pads to make it all even.
Good luck and post back how you make out.
Jan 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have assembled my Peg Perego Pliko switch, but cannot make the back of the bassinett to lay flat. It bends as though it needs to snap in. Is this normal or does it indeed snap flat? Thank you in...
If you talking about the bend/hump in the middle of the seat, top to bottom, I haven't gotten mine (2009 model) to lay flat either unless my daughter is in it. But the back rest does lay completely flat and she's been able to nap in it. As long as the seat is correctly attached at the sides near the "handle bars" and corresponding dots, it should be safe to use.
Nov 03, 2010 | Peg Perego Pliko Switch Classico Java...
I have a peg perego viaggio sip and how do I remove the toddler seat?
You do'nt have to take the seat of it just needs to be reclined flat to fit a carseat.
Jul 28, 2009 | Peg Perego Pliko Hood Stroller
Rubber lining all 'twisted'? on front loading LG washer -- the washer was moved down the stairs by someone -- now the rubber appears all twisted and not lying flat like it was before. Do I need to remove...
Sounds like the suspension spring or springs have become detached, or the suspension legs have become dislodged.
Redmove the top to check for detached spring, if o/k, then check underneath the washer, and see if the suspensions are o/k.
Please rate my solution.
Thanks.,
Jun 22, 2009 | LG WM-1832C Front Load Washer
5 point harness reattachment - HELP
Contact Peg Perego & they will give you answers over the phone or send you a manual for free (email or snail mail).
800-671-1701
Jul 30, 2008 | Peg Perego Pliko P3 Classico Freestyle...
How do I fold the Peg Perego Pliko P3 and unfold
You can download the instruction booklet off the Mama's and Papas website :)
http://www.mamasandpapas.co.uk/downloads/product_manuals_pdf/001_pushchairs_raincovers/Pliko%20Pramette.pdf
Jan 23, 2008 | Peg Perego Pliko P3 Classico Freestyle...
Peg Perego Pliko Hood Stroller Logo
90 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
