ERROR: Antenna Not Detected
I am having a problem and narrowed it down to the receiver unit. The header connection on the bottom of the receiver seems to have a loose connection for the antenna. Do you have any tips on getting this to work without replacing the receiver. Is it possible to get a new header connection & solder it in place?
Thanks,
Gary
  • 1 more comment
  • johnspnc Jun 30, 2008
    I have
    I have the same problem with my receiver. Please let me know if you find an answer.
  • carversand2 Sep 10, 2008
    i have connected everything and it tells me that its acquiring signal when my other recievers are picking up the signal
My PNP2 unit has a few of the prongs missing where the antenna mount connects to the back of the reciever, when its in my car, i usually just pull the reciever out of the craddle just a small amount and it usually gets a connection. When its in my home dock, I use a bent credit card at the top to pry it out just a little to get a connection. Its a pain but seems to get it working.
Posted on Jan 28, 2009
No singal antenna on delphi sa10175
Could be the antenna, the dock, or the radio itself. If you have another kit or boombox, I would try swapping antennas out and so forth to narrow down which part is causing the issue. www.tss-radio.com has replacement parts.
Jun 03, 2012 | Delphi Roady XT XM Radio Receiver
Which plug(connection) on bottom of ST5 sirius radio is the antenna plug?? keeps losing the antenna, i have replaced the base with the same error ocuring
The small, gold, circular connector on the bottom of the unit. You can purchase a repair on eBay if the antenna connection has loosened itself from the board.
Aug 16, 2011 | Sirius Starmate ST2 Satellite Radio...
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
It tells me there is no antenna not detected
Antenna not detected could be caused by one of three things: The antenna, the docking station, or the receiver. If you have other equipment to troubleshoot, you can narrow down what is causing your issue and replace it. tss-radio.com is a good source for parts and trouble shooting ;)
Jun 14, 2011 | Sirius Satellite Radio Sirius Sportster...
No antenna detected
More than likely, it is the antenna. Sad to say, but the Sirius antennas go bad very easily. Make sure there is no undue pressure on the antenna wire itself, as that can aide to premature failure. Bad antennas are the number one reason for the unit to read 'antenna not detected.' I have seen plenty of the antennas go bad and they were not misused one bit. If you contact Sirius, they're usually pretty good at understanding the misfortune of losing your paid service. Sometimes they'll ship you out a new antenna.
May 11, 2008 | Xact Communication XTR1 SIRIUS Radio...
Surius Can not find antenna
A couple of possibilities all based on the assumption that the unit actually turns on.
1. Broken or disconnected antenna wire.
2. Broken antenna (The antenna is powered from the unit)
3. Broken unit.
Dec 27, 2007 | Sirius Satellite Radio Receiver
Antenna
I, my brother and a guy at work had the same problem. I don't know how it happends but your antenna went out. You need to get a new one.
Oct 14, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power Only
i have the same damn problem its crazy
Apr 27, 2007 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
No antenna detected
i had the same problem and had to return the antenna to radio shack to get a replacement. the guy said that the antenna had a crack in it from the cold weather or water got into the antenna and that is why it malfunctioned.
Feb 06, 2007 | Sirius Satellite Radio Sirius Sportster...
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
415 people viewed this question
 Grubhead
Grubhead
