Question about HP LaserJet 3055 All-In-One Printer
No Paper in Document Feeder
Hi Techies
I'm trying to scan a document, but I keep getting the message back no paper in document feeder?????
Can you help.
Sambo
  • 6 more comments
  • kalemukund9 Jun 26, 2008
    When i going to scan paper, below message are coming on screen.
    No paper in document feeder
  • Anonymous Jul 20, 2008
    I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3055. Their is paper in the document feeder, and it is registered my 3055 but not by the computer. How to solve this problem ?
  • Anonymous Aug 07, 2008
    same problem-same machine
  • txrower Aug 07, 2008
    When I try to scan docs from the ADF, I get a message on my computer (not the AIO display) that there's no paper in the feeder. Been trying to resolve this issue for over a week now with no success. I've uninstalled/reinstalled the printer software, powered down the printer several times, tried to scan from the glass rather than the ADF and nothing has worked.
  • sashasa Nov 24, 2008
    When i connecting the scan .error msg has comming "there is no paper in the document feeder.
  • Anonymous Dec 02, 2008
    When I try to scan it says no paper in document feeder ??
  • Anonymous Mar 17, 2009
    it happen the same to 3055 model
  • Anonymous Apr 21, 2009
    same problem
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
Posted on Jul 14, 2010
Click on where it says "Source:" and instead of having it on "Feeder (Scan One Side), click the option that says "Flatbed." It works for me, so hopefully it does for you too.
Posted on Oct 07, 2011
  • Anonymous Aug 07, 2015
    Thanks for the correct information. When I click on "Flatbed" it worked!
Plz send solution of document feeder error on my email id its urgent, i shall vry thankful to u .
Posted on Sep 15, 2008
When i connecting scan,there is no paper in the document feeder .But paper is in the glass.Pls help me.
Thnaks
Rgds
S.SARAVANAN
Posted on Nov 24, 2008
Posted on Jun 28, 2011
KEEP GETTING THE MESSAGE......NO PAPER IN DOCUMENT FEEDER. I am using an HPOFFICEJETJ3050 ALL-IN-ONE.
Posted on Jan 21, 2014
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
We keep getting the message that the document feeder is jammed but there is nothing in there and as soon as you put even one piece of paper in the error message pops up. Is there an easy fix?
Hey, if you're getting the Jam at Document feeder error even though there is no paper jam. First try turning the machine off and back on, if the problem continues you most likely need to replace the DADF assembly (document feeder) part# 004K07270. The part is a little expensive, but you can buy it as an exchange for your bad one from iteminc.com to save you money. Replacing the part is pretty simple, here is a video that shows you how.
Jul 04, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
Paper in document feeder
there is no paper in document feeder
May 24, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
HP LaserJet 3055 All-In-One Printer Logo
6,491 people viewed this question
Seeker5211
Seeker5211
