Question about Dell Inspiron 5100 Notebook
Dell 5100 laptop memory upgrade
Changed RAM fron 2 x 256 to 2 x 512 and now will not boot up, replaced 256 and still wont boot up ?
  • Anonymous Jun 14, 2008
    I have a dell 5100 and tried to upgrade memory from 512 to 1024 MB. The computer will boot with 512 + 256 chips but not with two 512 MB chips. Original memory was two 256 MB chips.
  • mc_s May 15, 2009
    I am having the same problem with my dell 5100. I upgraded to 2 512 mb chips and now the computer will not boot up.
I have Dell 5100, now I want upgrade Ram to 1024 Mb. Bus Market on ly Ram bus 333 not 266 Mhz. Can I upgrade my PC with Ram bus 333?
Posted on Aug 21, 2008
  • 139 Answers
Try removing it again power on then off. again put yr ram it should boot. less u want to may be remove the processor then put it back as well at times they could stop system from booting
Posted on May 24, 2008
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
Hi, I have a dell dimension 5100. I inserted a 1gb ram but it was the wrong one. I took it out and replaced it with the old ones. Now the computer doesn't boot properly - turns on but doesn't load...
Remove all the memories and insert them again, make sure you insert them in the proper way as the slot is keyed.
Memory issues can be identified by the beep sounds.
If you have more than one memory, remove one and insert only one of them and try to boot.
Hope this will help.
Aug 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Hi, I want to upgrade my Acer Aspire 5100 memory to DDR2-800Mhz. Can I do it? Will the motherboard bus support it?
Sorry but the specs for this system states the highest possible ram is DDR2-667 with a max of 4 GB ( 2 X 2gb Ram)
May 11, 2009 | Acer Aspire 5100 Notebook
Dell latitude d620 wont turn on
Did you upgrade the RAM when you upgraded to Vista. The D620 does not have the resources to run vista as pre-configured and requires, at the least, a memory upgrade. 1gb or greater is recommended.
Please upgrade the ram, or try F8 during boot for Safe-Mode and see if your RAM is not the issue. To check the amount of RAM you have:
Press and Hold Windows Key + PauseBreak
If you still have 256mb or 512mb vista is likely to barely crawl.
Let us know what you find.
Apr 17, 2009 | Dell Latitude D620 Notebook
Your harddisk MBR sector might be damaged, google fix mbr and resetup your harddisk mbr. After that it most likely will boot.
Dec 12, 2008 | Acer Aspire 5100 Notebook
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Installing ram
You need to go into the bio and update the memory there and the Yellow ! will go away. Boot the PC, select the F8 key during post, go into the setting for Memory and accept the change and you should be good to go. Let me know //D
Apr 25, 2008 | Dell Inspiron 1000 Notebook
What kind of ram?
just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
seee below
Nov 23, 2007 | Acer Aspire 5100 Notebook
Dell Inspiron 5100 Notebook Logo
484 people viewed this question
Alun Cox
