Question about Cameras
On my camera the battery charger light is blinking and the battery is not charging
  • 3 more comments
  • Genevieve M Jun 11, 2008
    the light on my charger flashes red than green but than my camera wont charge at all. It does the same thing if i plug it in the computer to charge it also.
  • eslsteved Jun 22, 2008
    Oops...That shouldn't have been posted as solution
  • lonis Jul 08, 2008
    Mine is doing the same thing. The battery charger light is blinking red and the battery is not charging. Before this the light would stay red until the battery was charged then turn green.
  • Anonymous Oct 20, 2008
    Flashing red continuously and not charging. Manual calls this charger error, but no remedial advice offered. Help. Camera obviously does not work
  • Anonymous Nov 15, 2008
    i have the same problem!
    does this mean that i have to get a new battery or charger, or camera?!
    what does this mean ?
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
Posted on Mar 19, 2010
  • meyou417 Nov 14, 2010
    same thing happened to me, but now it wont charge in any of the sockets at my house. what should i do? my camera is Kodak M1033. im planning yo buy a battery charger but i dont know if kodak has one.
Yeah, get a cell phone charger and cut the wire to expose the copper underneath. Attach the red to the positive terminal of the battery and the black to the negative. Leave the middle Terminal 'T' exposed and plug the cell charger to the wall with the camera battery attached. Leave for 5 to 10 mins and then use the original charger that came with the camera and this should do it.
Posted on Nov 02, 2008
I modified nick_9035's solution a bit. I connected the camera battery first to a 9v battery, connecting it to the corresponding positive and negative terminals for one minute. even 2 AAA batteries would do. then I looked for a different outlet and plugged it in. worked like a charm! (note that when I changed outlets without doing this, the camera charger still kept on blinking)
Posted on Oct 23, 2010
Why can't I charge the battery? It gives me a blinking amber light.
Steps : Check the type of batteries you are using. Many a times , less powerful batteries gives issues.When u r charging External charger with battery - will give you blinking light .. which is the indicator for charging.. Check the manuals of the charger to see the meaning .. I feel that you need a replacement battery Or charger needs a repair.. Your question is not very clear though.!
May 10, 2015 | Samsung Pl20 - 14.2 Megapixel, 5x Optical...
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
The charger of Dsc-t5 is blinking
The supplied charger normally lights while charging and turn off when the battery is fully charged. If the battery charger is blinking, then issue may be with the battery not getting charged. I suggest that you try using a different battery and check if the issue is with the battery.
Thanks for using FixYa.
May 12, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
The charger red light kept blinking while im trying to charge the batteries. after charge the battery overnight, the battery went dead after i took a few photos. does the problem lies in battery or...
Welcome to FixYa.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Olympus Stylus 790SW Digital Camera
I go to charge the battery and it looks like it charges for a while then the charger red light starts blinking. I put the battery back in the camera and the battery is still flat. Not sure what's wrong?...
The blinking light on the charger indicates that the battery needs to be replaced and will not charge. You can buy a replacement lithium battery online at sites like Amazon for less than $10.
Nov 18, 2010 | Olympus Stylus 820 Digital Camera
Battery charging
Usually when the light on the charger either changes from red to green, or some chargers have a blinking light, when it stops blinking. I have seen chargers which also had a light which would turn off when the battery is charged.
Apr 12, 2010 | Fuji FinePix J10 Digital Camera
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Battery charger(BC-11L)
Your Battery is faulty and requires replacment.
Depending on where you are and if it is still within the new warranty period or not depends on how long or how much it will cost to replace the battery. Call the Distributor for Casio in your State or Country and they may even send you one out Free Of Charge.
Jun 23, 2008 | Casio Exilim EXZ75 Digital Camera
Cameras Logo
1,459 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
