Question about Philips Televison & Video
I have a philips model# 20dv693r02 t.v.w/a built in dvd player. I cannot get the clicker to enter any channels above 55.I have over 200 channels and need help resetting my t.v. to be able to watch them! Thanks! Jenny Collins okuome1@indy.rr.com
I downloaded the user manual that had been lost long ago. PDF. Print & go. Thx :-)
Posted on May 24, 2008
How do i record from tv to vcr and play back
Leon, I believe models that are able to do this have a built in tuner, so that means cable would go into VCR/DVD player/recorder then to TV.
Your TV would be set on Channel 3 or 4 and the VCR/DVD would then be used to change channels and also allow recording of program.
Feb 20, 2016 | Televison & Video
Phillips Model DVDR7310H DVD Player
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Sep 22, 2008 | Televison & Video
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a philips universal remote and i need the code for my tv which is a sv2000 with the dvd player built in
Hello crystal and welcome to FixYa. I think you were searching for the remote codes for a SV2000 TV/DVD Combo. Generally speaking TV/DVD Combos do not have a traditional codeset but instead use a DVD one instead. Follow these steps below.
Search the TV codes Using AV1 or AV2
Press and hold Mute and Select for two blinks
Enter 9 11
Enter 2
Press and release Volume Up
Press and release Channel Up until you hear the volume change
Next after hearing the volume change press Select to lock in the code
You should be all set. I hope this solution works out for you and good luck.
Apr 22, 2011 | Televison & Video
Can't run a Dual layer DVD Philips DVD player DVP3005/69
You Don't!
moz-screenshot-2.jpgmoz-screenshot-3.jpgwww.p4c.philips.com/files/d/dvp3005_69/dvp3005_69_pss_aen.pdf
click on the link above and download a PDF on the model you have, and in the 2 pages you will never see any mention of 2 Layer media.
Apr 25, 2009 | Philips Televison & Video
Unable to select channels using the unit
First, test to make sure the Philips remote is working by trying to play a dvd. If the remote control is working, then either A) your TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
Dec 25, 2008 | Philips DVDR3576H DVD Recorder
Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Nov 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot do timer recording
I need more information, what kind of recorder is? it has built in tv tuner?
Nov 11, 2008 | Philips Magnavox DVD/VCR Dual Player
DVP3345V/17 can't watch TV Programs
I would like a insturction book, as I never receiver one. I can't fine the channel on the vcr to match the channel on the tv. to tape. My Name Carol King
Address 229 Billings Ave.
Paulsboro., Nj. 08066 Thanking you
Carol King
Model #DVP3345v/17
Serial #SG1A0816014102 Make Philips VCR/DVD
Aug 16, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a Philips Model DVDR 3505/37 recorder. I recently hooked up a RCA analog to digital converter to the TV and to the DVD. Now it will not record. No error messages. Just no recording. Thanks
The Philips DVDR 3505/37 has a built-in analog to Digital converter. No additional converter is needed. Just do the scan for over the air channels and set to go. Works fine now.
robert2792@sbcglobal.net
Apr 28, 2008 | Philips Televison & Video
Televison & Video Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
