Question about Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2)
Driving force pro ps2 not 900 degree rotation
GT 4 ps2 doesnt do the full 900 degree rotation thing. All working fine otherwise..any clues?
  • stitson May 26, 2008
    Hi there, The wheel is functioning as if it were stuck in 200 degree rotation mode. at start up it calibrates but only 200 degrees. the left LED lights ut not the right LED. On scren it functions as if it were in 200 degree mode also. Hope this is enough info, thanks...
    Hi, the wheel works with the ps2 but doesnt calibrate for 900 degree rotation, ie the wheel only physically turns 200-300 degrees (not sure exactly but its the default for games which dont support 900 degree rotation). After start up the left LED lights but the right one doesnt do a thing, Thanks.
  • 3,037 Answers
The sensor inside the steering wheel has been broken most likely. Does it still give you some rotation? Also the wheel I assume turns and by rotation, you mean turning on the screen? You will need to open up the control and have a look at the internal components and see if anything has been knocked loose or is broken. Try shaking it first to see if you hear anything. Let me know what you find and we can work from there to get this working again. Please try to describe this a little more and get back to me on this and I would be glad to help further.
Posted on May 25, 2008
  • Benjamin Patri
    Benjamin Patri May 26, 2008
    Internal wiring is definitely at fault, either start opening it up and looking for a broken connection or get a new one. If it is still under warranty, don't try to open it, just return it and get a new one. If you have any questions about opening, let me know, but that is your only option to fix it since it is an internal problem, good luck
    Sergeant:
    Champion:
  • 241 Answers
Is the wheel stuck or it does turn but ps2 doesn't detect it ??
either way you will have to open it up to fix it. let me know which is it
  • Logitech Master
  • 13,433 Answers
I'm not sure what you mean with the 900 rotationg thing can you clarify?
Samsung corby pro full key pad not working only touch pad working
there must be fault in keypad.contact your device dealer and change the keypad of your problem.this will fix your problem
Dec 27, 2010 | Samsung B5310 Cell Phone
1994 Toyota 4Runner Overheating
I had the same problem - my 95 4Runner would overheat in 4WD only, and coolant would bubble out and spill over.
The problem turned out to be with the rear heater tubes and the fan clutch - my mechanic bypassed the rear heater tubes and I have no more problems. Not exactly sure why this helped. To replace the rear heater tubes, it would've cost $325, but to bypass cost $75. Most people don't even really use the heat in the back seat.
The second part of the problem, and most important, was the fan clutch needed to be replaced. At low speeds, it wasn't kicking in when it should have been, only working at higher speeds. Once I replaced the fan clutch and the bypassed the rear heater tubes, all has been well.
Hope this helps!!
Nov 22, 2009 | 1995 Toyota 4Runner
Need manual for driving force gt
    Please download the manual link given below
http://www.generalmanual.com/Gaming/Logitech-963293-0403-Driving-Force-Pro-Racing-Wheel.htm
Thanks for using fixya.
Jun 01, 2009 | Logitech Driving Force GT Wheel for...
Range of wireless very limited
go to http://192.168.1.1
use username - admin pw - admin
go to setup->wireless->advanced... set the power level -> full
it will work
Apr 20, 2009 | U.S. Robotics (USR5633A) Modem
Force gt wheel doesnt steer, everything else works fine?
The wheel should be plugged in and powered up before turning on the PS3. While booting the wheel should go through its full range of motion and the horn button light will stop blinking and stay on steady. If the light doesn't stop blinking the wheel failed to calibrate and is probably defective. I had to exchange mine and did end up getting one that worked this time.
Jan 10, 2009 | Logitech Driving Force GT Wheel for...
Re: Logitech GT Force Wheel
I know this sounds stupid, but mine did the same thing until I remembered that it also has a power supply that has to be plugged into an outlet. I had simply connected the USB cable and got the green light on the top left hand side but it wouldn't respond otherwise. Sorry if you already have this checked but it solved the problem for me.
Jan 02, 2008 | Logitech Driving Force Pro (963293) Wheel...
Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2) Logo
341 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
