Question about HP PSC 1610 All-In-One InkJet Printer
Printer Hello, can you tell me please, in which website can I see the image showing how to open my printer 1610xi, I want to remove a small memory card that have been stock inside of the "xd"
  • 2amor4 May 23, 2008
    Thank you for your comments
  • 2amor4 May 25, 2008
    Thank you very much varungrover that was very nice of you give me this comment I click inappropriate because I don't need that,what I want is a site showing how to open my printer to remove it
    Thanks again
    Champion:
  • 207 Answers
Ill give u a tweak if ur printer is in warrenty call tech support and ask for teh replacment of the whole printer
Posted on May 23, 2008
  • varun grover May 23, 2008
    thx for being rude
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error 1203
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
5. Cont…
February 27, 2010 10:27 AM
Feb 06, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
Feb 02, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have a HP PSC 1610xi All in One printer. I
you know what to do is dis, check your key board wether it has be press dawn or the upu had been shake when you are taken it home
Oct 16, 2009 | Office Equipment & Supplies
SOLVE ME
could u send medetails at suyyam@gmail.com
if you talking about website and broweser doesnot show images go to option button in tools manu and enable show picture of your browser
Jul 22, 2009 | Tally 6306 Matrix Printer
Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 20, 2009 | Brother HL-4070CDW Printer
I own a pink Fujifilm Finepix z20fd and everytime I slide open the front it reads a warning that reads: "CARD NOT INITIALIZED" and when I put the memory card into my HP PSC 1610Xi All-in-One...
The problem seems to be in the card not the camera ..... try formatting the card ...... also check whether the card is readable on the computer or no .... otherwise replace the card
Oct 19, 2008 | Cameras
HP PSC 1610 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
