I have been looking at diagrams but i cannot determine where at what is the PiP module. I have changed the stk chips on it and the capacitors next to the chips but i continue to have a warped screen imust have not changed the right capacitors or something else is burned.
The PIP module is a board that allows you to view two different pictures on your set . Also if your having a convergence problem you might want to suspect an opened fuse that supplys the voltage or possible opened resistors could be causing the problem that your still having . A volt-ohm meter would be helpful in finding your cause . Also be cafeful when checking any electrical device when power is active . Your problem is not your PIP module if your colors are not aligned . Good luck
Was this solution helpful? Show your Appreciation by rating it:
