Question about Kenmore Elite 45986 Front Load Washer
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
The control locked light is lit and it will not allow me to do anything else. I have pushed OPTION AND SELECT button at the same time to unlock and it is not responding. How do I reset this and how did this happen? Help I need to do laundry!
  • 1 more comment
  • Anonymous Oct 26, 2008
    there is no water in the washer but the control lock is on ive pushed the option and select button at the same time and nothing happens
  • driscollpaul Nov 09, 2008
    same problem with control light on - have pushed every button and nothing works.
  • Anonymous Jan 22, 2009
    How do I reset the washer? The red lock button will not let me do anything.
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
Posted on Jul 13, 2009
  • lisatimjohns May 18, 2011
    Yes, it worked but the door has to be open. Thanks you saved me a service fee!
The red "lock" light indicates a problem in the washer. In most cases, the lint trap needs to be emptied. Make sure the washer is unplugged. On newer models it is behind the small door on the bottom of the washer in the front. On older models you must remove the lower panel to get to it. Newer models have a spout inside that folds down, older ones don't. You'll need a dish about 2" deep to catch water. Slowly unscrew the filter, water will start to trickle out. If the dish fill up, screw the trap back in til the water stops & empty the dish. Repeat until there's no more water. Then completely unscrew the filter & empty. It's also a good idea to wash it with hot water, as it will probably stink. Replace the filter & make sure you don't over tighten (after all, it's just plastic). Keep a rubber mat under the washer during the 1st load, in case it's not tight enough. Close the door or reattach the panel when you're sure it's in properly. When you plug it back in, the red light will probably come back on. I just held the "lock" button, beside the power button for a few seconds. It beeped & the light went out. I did this with the door closed. If it doesn't work on your model, try the other suggestions here for getting rid of the "lock" light. Washer has worked perfectly since cleaning the trap.
Posted on Feb 07, 2012
This issue seems to happen from time to time when you unplug and plug this unit back in. If you see a green light next to the "Control Lock" button your lock is active and none of the controls will work.
To unlock the controls hold down "options" and "select" together until the control lock turns off (around 20 seconds). Control Lock light will turn of and the washer will be back to normal.
This is used as a child safety lock if you don't want someone using the washer or kids playing with it. I think it is a defect since it should not activate when you unplug and plug the unit in.
Posted on Feb 01, 2011
  • 240 Answers
Is it full of water? if so drain then it should reset. sounds like a frigidaire built machine, so drain pump underneath in middle, without cleanout port. remove hose at tub and check hose and basket if equipped for debris. check pump end. tech sheet at lower front left will tell how to engage pump in diagnostic.
Posted on Jun 03, 2008
Control locked is lit up and not allowing me to start another load of laundry. What do I do?
Please avoid answering questions of which you know NOTHING.
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(tip courtesy JS Rock)
Thanks for using FixYa
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is lit up and will not go to any
This happens often, pressing buttons, sometimes it can be easy to slide into control lock. I have this link that shows how to turn it off.
http://www.managemylife.com/mmh/questions/193855-how-do-i-disable-the-control-lock-on-my-duet-washer
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
4,533 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
