Philips 60PW9363 60" Rear Projection Television Logo
steve billings Posted on May 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound with a scrambled picture
I have perfect sound. The pitcure is really scrambled with colors, but you cannot make out what is on the screen.
Anonymous
Level 3:
  • Master 426 Answers
  • Posted on May 28, 2008
Anonymous
Master
Level 3:
Answers
426
Questions
Helped
194244
Points
1076
You have routed something thru a vcr or dvd player you can not have a vcr plugged in to another vcr or dvd player or the other way around this is done to prevent copying of dvd's if you need any other help feel free to email me a [email protected]
How do I troubleshoot a Toshiba 42HP66 T-CON board? Thank You
that's a plasma. it doesn't have a t conn. can you send picture ? sounds like main board
Sylvania hdtv model lc320sl1 will turn on but does not get picture.... sound works.... various colored lines and or scrambled picture appears at best
Let me start at the beginning---Likely a bad main board in your case but nothing is sure in this type of set.
Main board controls all information to the front screen and communicates to various boards---There really is almost never a simple "that part is bad solution" as any board, the power supply, the main, etc can cause issues.
It can even be a issue with the front screen unit--called a display panel.
You might consider doing some research on the set by Google of the model number with "parts" to get an idea what is available and what potential parts cost might be.
If a main board is bad it will average from one to two hundred just for the part----if issue is the panel you are done--part if even available is more than set cost when new.
Let me know if you have questions.
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Screen fade in and out, then picture scrambles when the fan turns off, the fan makes a really loud noise when starting.
sounds more like a color wheel issue rather than a fan. Can you verify where the sound is coming from?
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
LOST PITCURES
The pictures may be in a subfolder, but they should still show up while you are in playback mode.
If the images are erased, don't take anymore with the camera and download free software recovery program from www.Z-A-recovery.com I hear that it works well.
You will need a card reader to try to recover your images...assuming they are lost. Even if they are not lost, a card reader may help them show up for you.
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
