Question about Whirlpool GH7155XHS Microwave Oven
Microwave dead, no power.
My serial # is GH 7155XKQ-0 its white. The fuse is good and power at the outlet. Is the thermosenser on this model located on the bottom front just behind the control panel? The marking on this part is PW-2R Z101 49/56. It checks open but not sure if this is the thermosenser.
  • 525 Answers
The thermal sensor is about the size of a dime, black with 2 wires to it, and attached to the oven cavity. It should be a normally closed circuit. bypassing this temporarily will show if it is open or closed. If oven works, that is your problem, but do not use oven with this bypassed. It sounds like you have some electrical knowledge, but be very careful as there is high voltage potential inside the microwave.
Posted on May 23, 2008
Panasonic Microwave Oven unexplainedly without power. Model No. NNS954WF. Serial # 6A34160395.
If you remove the microwave case, follow the power cord inside the microwave to the fuse. Panasonics will usually have a 15 or 20 amp ceramic fuse available online or at a local appliance repair shop. Of course remove power from the MW and don't touch any wiring or terminals except the fuse wiring.
Nov 14, 2017 | Microwave Ovens
My Intellichef microwave model #K0936 has stopped working. I've tried different outlets but the microwave is not responding. Is there an internal fuse that has blown or is the microwave dead?
If the fuse is blown the microwave will be "dead". The fuse is accessed by removing the cover. You can usually find the fuse by following the power cord into the microwave. Unplug the microwave and don't touch anything except the fuse as the capacitor can hold an electrical charge.
Nov 02, 2017 | Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
My GE spacemaker xl1400 model JVM1451BA 001 DOES NOT TURN ON, serial # HT9897895 , it wont make a noise or nothing, not lights, someone told me its a fuse, but I dont know what the fuse is called to go to...
First try plugging it in a different power outlet to eliminate a possible defective AC outlet, than if it still does not work, your friend could be correct it could be a fuse, if you have electrical skills you can verify your self. first unplug the power cable, than unscrew the cover to get to the electronic board, locate all the ceramic fuses and with a good multimeter set to (Ohms) check the continuity of all fuses if it reads 0 ohms it's good if it reads nothing than it is bad, replace that fuse with the same amperage and type than put the cover of the oven back, plug the power cable and give it a test if the fuse burns again than the problem is much worse, it could be a defective safety switch on the door frame or a defective circuit board, take it to a good repair shop...
REMEMBER TO ALWAYS UNPLUG THE POWER CABLE BEFORE OPENING THE UNIT!!!
Hope this helps!
Jun 18, 2011 | Microwave Ovens
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER...
most microwaves do have a fuse to protect the power supply .outer cabinet has to be removed and then you will be able to see it . look where the power cord comes into cabinet
Dec 01, 2017 | Magic Chef MCM660A Microwave Oven
Microwave is totaly dead
YOU WANT TO CHECK POWER FIRT AT THE OUTLET MAKE SURE YOU STILL HAVE 120 VOLTS THERE.. IF SO AND PLUG IS GOOD ON 98% OF THE MICROWAVES OUT THERE IS A 20 AMP fuse located in control panel of unit... check there with the power disconnected and may have a blown fuse...if that is good you most likely have a blown control on unit ...
hopw this helps good luck...
Jan 05, 2011 | Hotpoint RVM1325BW Microwave Oven
I have Whirlpool Microwave oven Model MH6110XEB-0 that has completely loss power. The outlet it is plug itno is still good with power running thru the outlet. I do not have any manuals for the microwave,...
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Oct 14, 2009 | Whirlpool MH3185XP Microwave Oven
Microwave doesn't have any power, ** Display, **thing...
Nice touch with the diagram. Thanks!
The neutral line passes through the cavity thermostat, which may be open. In the schematic, it's left of the center bottom.
In the pictorial diagram, it's located just below where you added the note "120V OK". Its top half is cut off in the picture and it has blue and white wires attached.
Also, the low voltage (LV) transformer shows fuses in its primary and secondary, although one or both may be internal and inaccessible.
It may also be a problem on the control board, which we repair nationwide for only $39.95 postpaid. Feel free to reply back if you need further assistance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 09, 2008 | Microwave Ovens
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Dec 20, 2007 | Whirlpool GH7155XHS Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
831 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
