Question about Acer Computers & Internet
My screen is broken, is there a way to use s-video with just the keyboard
    Scholar:
  • 139 Answers
All u will do for now is connect yr monitor(crt) signal cable to the vga port in yr laptop/notebook n every thing will work well.
less u want to replace the screen then ill give u a step on doing so.
xerick nigeria
Posted on May 23, 2008
Laptop dvd/rw has audio but no video
Step 1:
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 15, 2013 | Computers & Internet
Blank screen on acer 6642
Feb 12, 2013 | Acer Aspire V5-571P-6642 Nx.M49Aa.004...
I have a compaq and it starts up but screen stays black
Feb 10, 2013 | Computers & Internet
My screen stays black
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | Gateway M255-E Notebook
My screen is black
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Screen wont come on, on my Toshiba laptop computer
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
HP laptop screen is black
Jan 08, 2013 | HP VM114UA notebook
Hp pavilion dv7-4165dx black screen
Hope this helps
Nov 26, 2012 | Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Dual xdvd700 has been locked, broken remote, blue screen
you have to press the reset button then it will work
Sep 17, 2009 | Dual Car Audio & Video
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
