Question about Motorola Mobility RAZR V3
BlueTooth will suddenly not power on. I have used this phone with a Blue Ant system in one car and my new car is HandsFree wired. It worked fine until 2 days ago when suddenly it will not power on.
    Problem Solver:
  • 11 Answers
Sounds like a hardware issue. Probably a faulty BlueTooth chip set. Easiest solution is to bring it to your local cell phone dealer
Posted on May 24, 2008
Can i have how to connect Nokia BH-214 bluetooth headset pair in acer laptop(Asper5742)
from OFF state of your BH-214, press power button until LED flashes quickly,do not unhold, stay holding & press power button until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. I used Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer), work fine with my BH-214 to connect with PC (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile). Applied CSR bluetooth dongle 2.0, got from store for only $2.50.
Jan 04, 2011 | Nokia BH-214 Bluetooth Stereo Headset
HTC Touch P3450 - Bluetooth issue
Set your car stereo to play input from bluetooth, which is make and model of your stereo?
Apr 18, 2008 | HTC Touch P3450 Smartphone
My blue ant bluetooth handsfree won't work in bmw x5
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Nov 30, 2009 | Blueant Blue Ant 091193 Supertooth II...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Motorola handsfree kit
these kits are not very good and they are old, you are also unable to update software to work with new phones and the mic quality is poor.
go to your paired devices on your phones and change the hf850 to not connect automatically on both the phones, this may work.
If you can get a full refund and only pay the difference for a parrot it will be worth it. Also look at the THB Bury kit.
Dan
Mar 25, 2009 | Motorola Mobility Bluetooth??¢ HF850 Car...
Kenwood KVT-512 with bluetooth setup troubles
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Mar 02, 2009 | Kenwood KVT-512 Car DVD Player
Pairing
press and hold the button (on/off button) on the ear piece until the light becomes blinking blue and red. Turn on the bluetooth scanner of your phone and search. Select the handsfree and pair them. Simple.
If you turn on your handsfree and the light is blinking purple, that means you need to turn off the handsfree and restart with holding on to the button on the ear piece.
Feb 02, 2009 | Itech Clip IIe Wireless Headset
Motorola H700 Bluetooth connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Apr 01, 2008 | Motorola Mobility Bluetooth...
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
