Question about Malber WD1000 Front Load Washer/Dryer
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
  • 29 Answers
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Posted on Oct 03, 2010
  • mpn68261 Oct 30, 2014
    Thank you so much for the clear instructions. I ordered the part from the number you mentioned; they were terrific and the part arrived on the day they said it would! Thanks to your instructions, it only toook me a few minutes to remove the ring, remove the broken handle, insert the new one, and replace the ring. Amazing easy, once you know how! Thank you very much!
  • Betts Davis
    Betts Davis Oct 05, 2015
    Thank you. Great directions!
SOURCE:
Xf portfolio 2014.locks/unlocks via door handles.discovered drivers side passenger door unlocks with handle without key nearby setting off alarm.other doors remain correctly locked.keys lock/unlock ok
I suggest you try one of those instant download manuals. My nephew bought one for me when my car broke and we could fix it all by ourselves with the manual at www.reliable-store.com . This website is very good for this.
?Try it.
Mar 10, 2018 | Cars & Trucks
Where parts for malber 1000 could be found and ordered
go to the manufactures website and order the spares you need eric
Jan 14, 2018 | Malber WD1000 Front Load Washer/Dryer
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber washer dryer 800 handle broke. cant open door
As the handle will have to be replaced I would suggest calling for a service engineer is the only option ;-0(
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry and good luck.
John C
Mar 25, 2011 | Malber Washing Machines
The door mechanism for the dryer appears to have been burnt out. Where can I buy the piece?
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 28, 2010 | Malber TD700 Electric Dryer
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Door handle
Malber...hmmm..sounds like a european make, right? only way to find that is perhaps accessories at website?
Mar 11, 2008 | Malber P21 Front Load Washer
Door handle
I have done this myself, breaking same part and fixing. For parts call 718-767-7396 in NY. I hope they will ship to you if you are not in NY. Good luck!
Jan 16, 2008 | Malber P21 Front Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
1,745 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Android Man
Android Man
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
