Question about Dell Latitude D600 Notebook
Help Hi are you good at knowing about hard drives
  • Shortiej May 23, 2008
    Hi are you good at knowing about hard drives. I need to know what type my computer uses
    Scholar:
  • 139 Answers
To know the type of hard drive your computer uses. if u r using windows os, click on start--all programs--my computer. then right click on local disk c, then click on properties u will see some info about your hard disk. or
u click on start-all programs--right click on the my computer icon then click on properties, click on hardware at the top of the window,click on device manager then click on the + sign at beside the ide icon,u i'll see list of hard disk drive right click on the primary ide then click on properties. there u go all about yr hard disk will be displayed.
im xerick
Posted on May 23, 2008
How to format compaq laptop nx6110
Hi
you could try to do this
Please try to save any files or pictures that you need before you do this either to a usb spare hard drive or a usb pen drive because you will loose it all if you format or reinstall windows
press the power on key as well as the F11 key
hopefully this will take you into the factory restore
which will format the hard drive while it restores
if you just want to format the hard drive itself then you could remove the hard drive
connect it to another computer via a usb cable and use the other computer to format the hard drive that you removed
or there are some good software out there that you can bootup with and format your drive without removing it from your laptop
a bootable spotmau would do the trick but its not cheap to buy
norton system works is another good software
pleasse let us know if this has helped you
many thanks
Jul 08, 2011 | HP Compaq nx6110 PC Laptop
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Hi my model # is 5T020H2 it is 10 years old do you still have information on it
hi
does this help you ? maxtor is now Seagate as you probably know
these are specs about the drive
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
is there something in particular you need to know other than what is in this link ?
was this helpful ?
Nov 04, 2010 | Maxtor Hard Drive
My Iomega Model LDHD320-U is not being recognized by my computer. Power commection is good. No gringing noises, but I hear a normal sound hum when I hold the device to my ear. No overt problems noticed.
This generally means either there is a corrupted driver on your computer, a fault in the circuit board in the iOmega enclosure or a failure in the drive itself.
To test the driver, try the drive on a different computer first if it works there let me know and I can guide you through replacing the driver.
If it fails to work on another computer then try moving your hard drive into a new enclosure, the techs at your local PC shop should be able to do it for you.
If this works, you're in good shape, if not you may need to invest in some data recovery software or refer the drive to a professional. Either way let me know which method you prefer and I'll be happy to help.
Hope this helps FixYa,
Crankstart
Mar 23, 2010 | Iomega 33089 250 GB Hard Drive
Platinum off old hard drive discs ?
Don't believe this is true. Hard drive platters are made of aluminum, coated with a magnetic material. not platinum.
Sep 20, 2009 | Computers & Internet
Drive in NTFS and Still Won't Copy Large Files
Hi there! Maybe this will help you out.
I made this article to help people like you out.
I don't know of any solution if this doesn't work.
Hope the info worked, have a good week!
Jul 22, 2009 | Western Digital Passport WDXML800UE...
WANTED ERGO ELITE 300G HARD DRIVE CADDY
Hi there.
You will be able to purchase a hard drive enclosure/caddy from ebay or amazon.
Good luck and thanks for using FixYa!!
Apr 09, 2009 | Computers & Internet
Pls. help me with my new seagate external freeagent pro ( 500GB)
hi..there....i think if you can get e sata cable to connect between external and pc at you country is very bad news..but maybe you can get it in another store...last time when i visit bangkok thailand i'm very happy because i can get all componnet for pc..i buy a internal card reader that include the e sata connection is around 400 baht and the cable connector for it (power and data cable) is around 100 baht. so if you have friend at tahiland (bangkok) you may ask them to buy it for you and send it to your place....
Feb 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Installing a new hard drive
XP SP 2 supposedly has no limitations on hard drive size so if you selected it to use the maximum available space during setup it "should" have picked up the entire drive. The only other thing I can think of is to make sure you are running the latest BIOS on your system, so you may want to check into that if you haven't already. I hate to say this but you may have to rerun the XP setup from your CD and make absolutely sure that the maximum partition size is selected and that it matches the size you expect it should.
Good luck and let me know how it goes. I'll continue to research and will let you know if I find anything of any help.
J
Feb 23, 2008 | Dell Dimension 4550 PC Desktop
Dell Latitude D600 Notebook Logo
Alun Cox
