H:\ not accessible The file or directory is corrupted and unreadable
It shows as a drive on the root directory but does not read folder/file data, just says disk read error/ disk corrupted. Thats about it, am trying to recover data using GDBNT get data back NTFS. will keep you posted, thanks, meanwhile if you can come up with something much obliged.
  • 6 more comments
  • Ranfer May 24, 2008
    Have tried it on my latop as well, but am finally on my way, tried imaging the drive but no luck even with undisker. Now am finally using getdataback to retrieve it, this should work, am pretty confident. Every drive needs some free space for buffering data, problem is theres nothing in windows to prevent a drive from bieng filled to the brim as i learnt from this experience. Thanks a lot for your time, incase u think of something else, always welcome. Thanks again.
  • Ranfer Jun 14, 2008
    Kindly give me some more details on...
    1. External USB/internal sata/ide drive?
    2. Age of drive.
    3. What was the last known process the drive was executing, copying/backup....etc?
    4. What perating system you are using.
    Ranfer
  • rahul2verma Jul 23, 2008
    I am facing the same problem which others ar facing but there is no solution work for me so, tell me asp what to do? it shows M:/ is not accessible and the file or directory is corrupted and unreadable.So, plz provide me the solution as soon possible.
  • Anonymous Aug 11, 2008
    laptop hdd ide
  • sreta92 Jan 14, 2009
    H:\ not accessible The file or directory is corrupted and unreadable. I have the same problem. Friend gave me external HD WD 500gb to watch some movies. Me, fool, give to my friend that, and he unplug HD whitout conformition on Windows 2000 profesional, and restart and now is instead NTFS - RAW. Can I recover pictures and b up which is in word and than format, because movies is collateral damage, i can erase them. Please help me, and I am sorry for my english. i hope you understand me
  • RobMiles Jan 19, 2009
    I have an external had drive with the same problem. It an external 500GB Philips SPE3051CC/00. It is being acknowledged by my laptop by sounding and showing up in My Computer, but instead of its usual title 'PHILIPS EXTERNAL...' it is called 'Local Disk'. When trying to access the drive I am told "H: is not accessible. The is corrupted and unreadble." I have installed nothing since it last worked, not saved anythingon it or taken anything off and not moved the drive anywhere. Please help!!
    Thanks,
    Rob
  • RobMiles Jan 20, 2009
    I have the log from the event viewer from the time it was last working to the first time it stopped it that will be of any help for anyone? The drive is a Philips 500GB External Drive USB2, just over 9 months old. I'm running XP Home. All that I was doing before it stopped working was transferring a few .pdf files onto the laptop, nothing was scanning/defragging etc.
    Please Help!
  • er_parveenve
    er_parveenve Jul 26, 2012
    It works - U can recover only 1GB of data for free - Go for :http://www.powerdatarecovery.com/downloa...
How can i solve I:\ is not accessible the file or directory is corrupted and unreadable
Posted on Jun 14, 2008
    New Friend:
It's possible that files system, more exactly, the MFT or file allocation table is damaged. it may be caused by disk ejecting while the drive is still working. also it might be caused by virus infection. to fix this you can
step 1: retrieve data from the drive with recovery apps. since it can't be opened now, you need to restore data with professional to
ols.
If there is no important data on the drive, you can skip the step 1 and try the following solution:
Solution 1: format the drive directly. you can either format it under Disk Management or Windows Explorer with Quick Format.
Solution 2: carry out ChkDsk to repair file system errors. chkdsk /f g: g is the drive letter of the partition in question and it can be other letter in your case.
Type Y and hit Enter and restart computer to resume disk check if you get the message "Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? "
for detailed steps with screenshot you can go http://www.eassos.com/how-to/The-file-or-directory-is-corrupted-and-unreadable.php
Posted on Sep 09, 2015
    New Friend:
  • 29 Answers
Check this data recover software, it works in recovering your corrupt, deleted and lost files.
Posted on Oct 15, 2013
The file or directory is corrupted and unreadable....
how 2 solve
Posted on Jan 06, 2011
Ok i have the same problem, however, i put the hd in my sons pc, and it reads it fine.. wierd huh?
Posted on Sep 05, 2008
You will need to put up some more info about what type of drive it is, external/internal, what operating system you are with, how old is your drive, what was the last operation you used the drive for?
Ranfer
Im experiencing the same problem. The it is an external 2.5" drive. It is a Fujitsu 60gig HD. OS - XP SP2, Please let me know how to retrieve my data
Posted on Sep 18, 2008
    President:
  • 1,944 Answers
Thats not a good sign when it says disk read error/ disk corrupted. It usually indicates some sort of hardware failure. Did you try it with other USB ports or another computer for that matter? Look into the USB connector, maybe there is something foreign in there causing the errors (like dust).
Posted on May 24, 2008
"file or directory is corrupted and unreadable"
that happens when USB is disconnected. Might need to reinstall o/s drivers on pc or on hdd then do data recovery.
May 16, 2012 | Iomega Computers & Internet
You unplugged it when data was still written on it so it was corrupted. Some files are still recoverable so use
http://www.softpedia.com/get/System/Back-Up-and-Recovery/smart-recovery.shtml
to get them.
Jul 03, 2010 | Toshiba 120GB USB 2.0 Portable External...
The directory is corrupted and unreadable
The most common cause of this is removing the USB drive without clicking "Safely remove hardware" in the task bar. Especially if data is being written to the drive, this can result in corrupt files and may make the drive unusable.
I'm sorry to say the data may be unrecoverable--ALWAYS make backups!
Two things to try before you write-off the data as lost forever.
One: Try booting the computer in SAFE mode and see if you can pull files off the USB Drive--you may have to give the drive administrative privileges.
Two: Download and run the trial version of the BadCopy data recovery program at this link:
http://www.jufsoft.com/badcopy/
To make the drive usable again, find it in My Computer, RIGHT click on it and click "Format." The choose "Quick" format. A quick format should make it usable again.
If the BadCopy program could find no files to recover: After the quick format, you may be able to pull some of the files off simply in windows. If not, run BadCopy again: It just may find some files after the quick format.
A full format erases ALL data which may remain on the drive. Only use quick format if you expect to recover anything.
Good Luck!
Apr 05, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
File or directory corrupted and unreadable
The directory is like a "table of contents" in a printed textbook.
If a child's crayons have been used to overwrite those pages, making them unreadable, then the table of contents cannot be used to locate the starting page-number of a specific chapter. So, one must read through the whole textbook, page-by-page, looking & trying to recognize the start of a chapter, and then the end of the chapter.
Similarly, there exist "file-recovery" computer software programs that do such "linear" reading of the entire ZIP disk, and trying to reconstruct the "file-structure" that was recorded in the "disk-directory".
Search for "file scavenger" software, and give it a try.
Dec 08, 2009 | Computers & Internet
Photos don't show
Usually you are not limited in the number of folders you can create. You can have this problem if you are not createing folders to store the pictures in. Make sure ther are no pictures or other files outsde the folders in the root directory. If that does not help, that that drive to a camera store or coptuter shop that can do a data recovery. If there is a corruption in the USB directory then you may get problems like this as well. Reformatting the USB drive might help, but you will need to remove everything from it first. Chenck out http://www.spartanphotocenter.com/data-recovery-service.html
Sep 19, 2009 | Cameras
Directory corrupted - unreadable.
try to run chkdsk (checkdisk) ---- chkdsk c: /f /r
also probably you need recovery software (easy recovery professional)
Jun 29, 2009 | Western Digital Passport 320GB External...
Will not let me save a file and reads file permission error
I think for some reason there is a limit to the number of files (nb: number of files not amount of space used) that the root directory can handle. Try making folders and moving files into these to cut down on the number of root directory entries.
Apr 21, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Computers & Internet Logo
3,809 people viewed this question
David Payne
David Payne
