Question about Champion 2000+ Household Juice Extractor
Juicer motor The moter for the juicer is not working will not turn on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
You have to have the juicer attached, there is a little magnet that allows the machine to turn on.
Posted on Mar 01, 2009
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Motor failure
First, turn off the power at the circuit breaker and look for a small reset button. There should be one. If not, leave the juicer on off - and turn the circuit brkr. back on, and try again. If this still doesn't work. Check and see if you're plugged into a GFI receptacle, which has a little reset button on it. In fact, you can check this first. Good Luck to you! Feel free to contact me again if this doesn't work for you. - Jim
Mar 29, 2010 | Breville BJE200XL 700 Watts Juicer
My breville juicer won't turn on after working only minutes earlier. Did the motor burn out?
yep, you pressed to hard while juicing something not ripe or very leafy
Aug 20, 2009 | Breville 800JEXL Juicer
Motor not running
The stainless bar has a safety cut off switch at both ends. You have to put it back the same way to make the outer switch work.
Jun 17, 2009 | Jack Lalanne Power Juicer 250 Watts
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
DOES NOT ROTATE
What type of juicer is this any model number?
if motor turn on and shaft rotate it should work is that the case?
Oct 13, 2007 | Matfer SANTOS Juicer
Juicer problem
The fuse blew on mine, that could be it. I'm looking for a replacement fuse.
Mar 21, 2007 | Waring JEX 328 Health Juicer
Champion 2000+ Household Juice Extractor Logo
291 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
