Question about Compaq Armada E500 Notebook
Compaq armada 500 (touch pad not working)
Hi,I had stripped down my armada 500 to look at usb as I broke the little plastic tab separator,anyway once I built it back up all multi-plugs back in correct place,my laptop comes on ok but I cant get the touch pad to respond,ie,pointer I double checked the connectors and all seem fine,if I connect a external mouse it seems to work,can you help me?thanks.
  • buttons4u May 23, 2008
    Hi HellaNice,thanks for your thoughts,it turned out I,d missed a small connector that had creeped inside a board,thanks again.
    Champion:
  • 230 Answers
Look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
Posted on May 23, 2008
How to disable/enable touch pad on hp 6735s
well you will have to go to your bios settings first and disable you touch within the bios. plz let me no if you need help with the touch pad
or bois
Mar 21, 2014 | HP Compaq 6735s Notebook
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
Upgrade compaq armada e500
It has been a while but I think it isn't a zif but a standard low profile socket. You need a good light and check the edges to see if you can see the layers or where the cpu edges are. You should see the color differences between the plastic or the socket and the cpu. From above it will look like just a cpu but from the sides you should see the cpu overhand the socket a small bit or be flush with the edges.
The cpu has to be a M series P3 and you may need to adjust bus speeds and/or ram speed to make it work. May also have to upgrade bios as well.
Nov 17, 2011 | Compaq Armada E500 Notebook
Usb stivk doesn't work
It seem to be a driver problem reinstalling the driver should resolve the issue.
Nov 02, 2010 | Compaq Armada E500 Notebook
What holds on the pads
There should be a black plastic disc that fits tight over that white one. The black disc has lots of little spikes to engage with the pads.
Mar 26, 2010 | Oreck Orbiter Floor Machines ORB-500,...
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Touch pad is not working--COmpaq Presario B1900
Hold down the FN Key + F6 (OR the corresponding F key for the touchpad)
The B1900 can have its touch pad turned on and off.
Its a good feature when you just want to use an external mouse.
Hope this helps
Jul 04, 2008 | Compaq Presario Laptop
Armada 1700 laptop
remove the battery and power from the A/C and then plug in the battery and a/c cord
Jan 21, 2008 | Compaq Armada 1700 Notebook
Compaq Armada E500 Notebook Logo
149 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
