Question about Roper RAS6233KQ Top Load Washer
Wont spin I have a roper washer that will only spin sometimes
  • Anonymous May 26, 2008
    I have the same proble,- sometimes spins fine, other times needs a push to get started -- my husband said possibly the drive belt is slipping which would account for the sporadic not constant problem
  • Ray K May 27, 2008
    Roper washing machine RAS 7133 KQ. Sometimes needs a push to get the tub to spin, but not all of the time. Do you have any ideas?
  • 975 Answers
3 things you need to check , 1) check the sensor or latch switch when you close the door , 2) open washer and check the DRAIN MOTOR PUMP it could be clogged with debri in the impellers , and 3) timer switch module replace , hope this helps AJ
Posted on May 23, 2008
I have a roper ras8333pqo. Sometimes the washer will not spin and the motor will sounds as though it is spinning. I rotated the drum. I then closed the lid and it started to spin...is this the coupler? ...
Could be a bad clutch/brake mechanism or a bad coupler.
This video will show how to repair it.
http://www.youtube.com/user/RepairClinic#p/u/0/9K1KHEogf3c
Sep 04, 2011 | Roper RAS8445KQ Top Load Washer
My washer spins but will not drain. the pump seems to be working but wont drain
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
May 19, 2009 | Roper RAX4233PQ Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
I have a roper washe rmachine it wont spin
washing machine wont wash nor spin when time to rinse
Nov 22, 2008 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
My washing machine wont spin
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper Washer RTW4300SQ
if the drive coupling is ok then the transmission is the problem verify for sure that the coupling is good
Apr 18, 2008 | Roper RAS8244KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
