Question about Hotpoint TDC32 Electric Dryer
TDC 30 Dryer starts but after 5 mins "clicks and stops"
The clothes are getting hot and there is a lot of condensation in the dryer.
I have to wait about 5 mins before it will let me start it but then it clicks and stops again.
Its probably the relay (brown plastic box at the front under lid)! Symptoms are usually.... the dryer will go for a few minutes then shut down.... then you have to wait for it to start
Posted on Jun 06, 2008
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
I have a hotpoint aquarius tdc 30 conderser dryer. It gets hot and rotates the clothes, but they aren't drying. what's wrong?
Hi, Well if it is getting hot but not drying the clothes than most likely you have an airflow problem. Take off the vent hose on the back of the dryer. It will be plugged up with lint either inside that vent on the dryer or the hose will be plugged somewhere. If you clean this or just plain replace the old hose this will take care of the problem. Good Luck. feed back is appreciated.
Jan 12, 2011 | Hotpoint Dryers
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Splendid washer and condensing dryer combo
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Dec 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
373 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
