Have reached the point of Burning a DVD. the system keeps telling me that it has an error and must shut down. It has repeated this propmlem over and opver reaching from 1% to 62% of compleation before the error appears. Please help i need this presentation by tomorrow.
  • 975 Answers
Try re installing the driver of the dvd , or go to the HELP desk on your PC so it can run diagnostic test and fix the issue , hope this helps AJ
Posted on May 23, 2008
My pc keeps shutting down and starting up after checking the files its windows xp home
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 15, 2013 | Computers & Internet
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
Why does my computer keep crashing? I have an acer ASL-100-UD360Athat shuts down and says kernal-data-inpage-error then it starts dumping phsical memory and reboots. . I bought this computer from radishack...
With so many service calls for the same or similar problems, it would appear that another component in the system is burning out your motherboard and DVD drive. I'm willing to bet that your power supply is the issue.
If it is still under warranty, send it back and make that suggestion. Otherwise seriously consider a new computer. If you have to pay for repairs on this one, you will end up buying a new motherboard and a new power supply.
Mar 19, 2010 | Acer Aspire L100 PC Desktop
Computer keeps shuting down. GATEWAY desktop mod# Lx6810-01, ser# ptg590x00190910c3e2700 less than 2 yr old
Most likely this is an overheating situation.
If your CPU is running at over 60 degrees you might be at risk of burning it out. Some systems shut down automatically when the temperature reaches an unsafe level.
Every few weeks I open my system unit and clean the fins on the heat sink that sits under the CPU. When they collect dust it restricts the airflow and prevents proper cooling. I just did that on my system and the CPU temperature dropped by ten degrees!
If you determine that overheating is not the problem, the most likely suspect is bad memory. The best way to find the culprit is to pop open the system unit, remove (or replace) one RAM stick and see if the problem is solved. Run your system for a while and if the problem goes away, you win!
If not. lather, rinse and repeat for each RAM stick until you find the one that's misbehaving.
Jan 19, 2010 | Gateway Computers & Internet
MP3 to CD burning crashes Windows Media Player
i have no converter about it but there are others u maybe like
i prefer eztoosoft for its clear converting image and fast speed. The most important thing is that it is easy to use, especially for beginners. If you are interested, you can see its sites and make further comparison. I usually visit
http://www.eztoosoft.com/eztoo-dvd-ripper-for-mac.html
you can have a try.
Guidance
http://www.eztoosoft.com/eztoo-dvd-ripper-for-mac.html#guide
Apr 25, 2009 | Computers & Internet
I tried to install winoff25 from CNet to shut my system down. It obviously did not install properly, and now my Vista'd laptop will ont shut down. It just hangs, and I have to hold down the Off button. I...
you need to search a program that shut down your laptop a made on for myself but i cannot sent it to you ,but evan if you find a program it will not solve your problem i advice you to reinstal OS .
Jan 18, 2009 | Computers & Internet
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Hello. I am running vista home ultimate 64bit. Manually I am unable to create a restore point. Error message 0x8004230F unexpected error for shadow copy provider. I have check in the computer management...
Sometimes, Windows Vista Ultimate 64bit will not allow to create a restore point as it is self scheduled to create its own restore system restore points.
To over-come this: turn the system off, press the on button and keep pressing the F8 button to get into Safe Mode. Once you are in Safe Mode, go to the System Restore and then create a Restore Point. Once you have done this, shut down and restart the system, you will then see your restore point that you have created.
Hope this helps
PC Software Solutions PLC
pcsoftwaresolutions@techie.com
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
