Question about Dirt Devil M086365 Bagged Upright Vacuum
Wiring diagram for domel motor part no. Mo244
Looking to see how to wire a domel motor part no. M0244
  • David Emmel
    David Emmel May 24, 2008
    Issue has been resolved.
Wiring diagram
HI, tell me is this you want,,
Gunjan:-)
Oct 24, 2007 | Vacuums
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Explain how to re-wire 16gal craftsman shopvac,switch wires are- 2 orange wires, one white, one black and one green(grd wire), I pulled them off and don't where each wire goes.
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
I hope this helps you
If I have misunderstood your question, please ask again.
a
Oct 05, 2009 | Vacuums
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Wiring
backwards wiring. The motor will still run but the lights keep going out right?
Oct 23, 2007 | Oreck XL Ultra Bagged Upright Vacuum
Dirt Devil M086365 Bagged Upright Vacuum Logo
198 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
