Mitsubishi 35" CRT TV
Is it possible to fix a Mitsubishi TV that is almost 14 years old?
The TV picture has "waves" on the screen that appear on cable tv, DVD and antenna transmissions.
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Fuzzy or blurry picture
Ok with you I can skip the "do you have electronics experience?" questions. With 14 years under your belt you are a pro. So here we go. The problem you are experiencing is called blooming/loss of focus this occurs when there is an increase in CRT anode voltage and control of the electron guns (in the CRT) is lost. The result is the picture spreads and focus is affected. The problem can some times be taken care of by adjusting the focus control However if you have auto focus the auto focus circuitry might be the problem. The common parts (areas) to check are as follows: 1) Focus control (to see if the problem can be soled by adjustment) 2) IHVT anode (test to see if voltage is correct you will need a schematic and a high voltage probe) 3) CRT Socket board ( Check to see if the bias voltages and input signals are correct you will need a schematic, multimeter and oscilloscope) These would be the areas to check, I hope that you are seeing my point here. My next bit advise if not one of your experience, you have that, 14 years of it. However, you have little ones and they are your NUMBER ONE concern, So my advice would be to get the set repaired at a TV repair shop. The reason being is because even though I have named some places to start your troubleshooting, TV repair is not an easy thing and there may be other components that could have gone bad and you don't have the time to do investigative troubleshooting. I wish you well on this issue and take care of those little ones. Respectfully Submitted, Shuttle83
Posted on Sep 22, 2007
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
My parents have a Mitsubishi TV from 2000 and of course, there is no warranty. The picture on the screen has darkened and the clarity of colors is lost. Do you have an idea why this has happened? Is...
U mean they have this tv since the year 2000 to now?Yes?10 years old tv,not worth fixing.Get a new tv.Is this a CRT tv (Tube tv)?Yes,the CRT(Tv tube) is dying,radiation in the CRT tube is decaying.
Nov 24, 2010 | Mitsubishi Televison & Video
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
My TX is about 14 year old. The picture alwasy was excellent until we had an exlectrical storm that knocked out the cable box to the TV. With a new cable box the TV works. The picture has excellent color,...
Try your cable box on a different tv set and also try connecting the cable directly into the t.v, if that makes no difference then your tv set may have a power supply problem that was caused by an a.c line surge during that storm.
Oct 31, 2009 | RCA F19253BC TV
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
1992 35" TV has no picture...just a horizontal line
if you fix also not expensive just vertical ic problem
Jun 05, 2009 | Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
