Question about HP DeskJet 3745 Printer
Printer bling ect
Blinking light when put paper intray it takes all he paper at once . I used one piece of paper and the printer went thru the motions as if it were printing but nothing was printed
    Scholar:
  • 107 Answers
Dear friend this light blinging problem is with Print cartridge please check cartridge with Ok printer .
100% u r problem is solved ...
& at ones time Printer get all paper
this is a default printer tray alliment problem .so u take care that your paper bunch is no longer insetred in to printer just under pickup roller.
if problem is solved please Rate me ...
Posted on May 23, 2008
Testimonial: "expert was 100% correct"
  • Techpoint
    Techpoint Jun 10, 2008
    If this Information is useful for you please rate me as you wish......
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 46 Answers
Try to reinstall your printer.
Check your printer if there are pending tasks to print.
Check if you have still ink.
Replace your ink with original hp ink cartridge
Posted on Sep 12, 2012
I own a HP PSC 1500 All-in-One Printer. Recently, when I turn on the printer, the Check Paper and Check Print Cartridge lights (both orange lights) flash. I have gone to the HP Troubleshooting site, d
Have you installed the latest printer driver? What operating system do you have - Windows 7 or 8? This sounds kinda like your printer may have been slightly fried by a lightening strike. Is it protected by a surge protector? Can you print a test page from your operating system?
Nov 28, 2014 | HP Office Equipment & Supplies
My printer is printing crooked
If you mean it takes the paper in crooked then check your paper guides on the intray they need to hold the paper firmly. If they are Ok then it could be the rollers are worn or dirty and need replacement, a local printer repair center will be able to help, most printers are easily to replace the paper pickup rollers. Good luck
Mar 05, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
Printer feeder is not picking up the paper to print. Goes thru the motion like it is going to print but does not oick up the paper in the paper tray????
Please reset your printer ... your printer ink absorber is almost full. Follow the instruction... 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal. thanks....
Aug 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Paper got stuck because suddenly electricity went off.how do i get it out?i dont know how to pull out the cartrdige of how to put it back.
When paper get stuck inside your printer you have to make sure to turn the printer off before doing any action. Once the printer is "off", open the top cover of your LBP-2900, pull it up from the rightmost part just beside the paper light indicator. Pull out the cartridge then proceed with the paper inside it. Once the paper is gone, put back the cartridge slowly and firmly. Close the top cover and turn on the printer. If the paper light indicator is still blinking red, press the button and proceed using the printer when it turns green.
Jun 25, 2010 | Canon LASER SHOT LBP-2900 Printer
My HP Deskjet D1360 printer green light keep blinking.can't take printout.The machine does't get the paper inside. so send the solution
you have a paper jam
pull out the paper tray, check for the jam if all is well, open the printer, check under the printer cartridge, then the back
a little piece of paper will cause the jam
it is a good idea to use canned air to clean your printer, under the cartridge and the rollers on a regular basis (once a month)
Mar 01, 2009 | Computers & Internet
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
Canon i470D...code 302 (paper Jam) shows up on the digital screen. There is no jam. When this happended the document printed, but while printing reversed it self(paper went backward) then went properly...
I had the same problem. I took a card stock sheet of paper. When you turn the printer on and it trys to take the paper thru, I forced it thru and had some small pieces of paper come out. I had the front open so I could see what was happening. It fixed mine, hope it helps u.
May 06, 2008 | Office Equipment & Supplies
Printer-squeel
The squeeling I think has to do with a small build up of ink on the carriage.
What I do is I open up the printer top so you can see the carriage as if you were putting in a printhead and then you unplug the power to the printer when teh carriage is in the unlocked position. Now you can freely move the carriage back and forth. If you notice there is a clearish long strip going from one side of the printer to the other that is placed flat ontop of the entire metal inside casing of the printer. Clean that entire strip with a cloth or something. Now take a piece of paper and fold it a few times so that it ends up looking like a ruler you can say. Put the paper flat on that clear strip and then take the carriage and move it over the paper. Basically your cleaning the underpart of the carriage that touches that clear strip that is attached to the metal body of the printer. Move it back and forth and you will see ink being put onto the paper thus cleaning it.
Just close the case up, plug in your printer and the squeaking should be solved till next time. As for that light problem, don't know what those lights mean. If there is a problem with teh printhead or ink though it will always tell you on the digital read out, or at least should.
Jan 19, 2008 | Computers & Internet
My printer wont print
Leh1987, that piece of plastic you see hanging, is what the ink slides on, right now its broken so your ink cartridges are slamming back and fourth had the same problem, have to take it in and get the plastic piece either replaced (if damaged) or put back on.
Nov 17, 2007 | HP PSC 1410v All-in-One Printer
HP DeskJet 3745 Printer Logo
128 people viewed this question
Ben Johnson
