Question about Philips Televison & Video
Older 2006 tv had lines at the top about 1/8 of the way down from the top for 3 days, now tv has 1 red 1 blue and 1 green line on a black screen and will only get audio for 10 seconds and the it shuts itself off and the power light flashes tv is a 32" philips
  • smorrison May 23, 2008
    not a projection tv though could it be the pic tube
    um ya that will probably cost more than the tv is worth but thanks
  • 975 Answers
Needs to be serviced , looks like it needs some adjustments,but it need to be done inside the tv , hope it helps AJ
Posted on May 23, 2008
  • ALBERT GARCIA
    ALBERT GARCIA May 23, 2008
    THE problem is at the convergence section either adjustment or replace the ICs AJ
I have a 2011 Panasonic plasma tv I bought new in 2011 and today there is a red/blue stripped line 1-1.5 inches wide across the top and a dotted green/purple line 3-4 inches below the blue/red line.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 17, 2017 | Panasonic Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Picture of rear projection tv
Convergence amp ic are bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
Oct 13, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Weird lines on the screen
Needs convergence circuit repair----give complete service # off
back so I can get part #...........T.
Sep 16, 2007 | GE 46GW 948 46" Rear Projection Television
Have Virtical and horazonal lines ....Please help
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 14, 2007 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
