Question about Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Laser Fax
Reads Toner Empty - New toner installed
  • 30 Answers
In the box with the new toner cartridge was there a credit type card to use when changing the toner to reset the toner counter?
read the instructions in the box :p
Posted on Nov 19, 2008
Toner empty, but i have just installed a new toner
if you toner is empty replace it.
if you replaced it and it still say emty do the following
  • menu
  • 1
  • 9
  • 4
  • 3
you will go in service mode.
look for ignore toner put it on.
if it still not working open the fax take out the cartridge. you will see ontop of the cardrige is a fuse. put a new on in put cartrige back. close the door for 5 sec. and take cartrigde out and remove the fuse. it should work then.
Feb 08, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Toner Light reads empty
Already replace the cartridge?
Let me know the full details of your concern?
Sep 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
TONER EMPTY MSG
1-remove power from fax.
2-clean contact points in toner cartidge and the contact in fax which it make contact together.
3-knock above toner cartidge many times.
4-move it in horizontal direction from left to right many times.
Feb 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Toner
The way that cartridge works is by a fuse. When you first install it the printer calibrates itself to the new cartridge and blows the fuse. look for a blown fuse in your fax. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Anyway, if the printer senses an improper toner/developer balance it will default to XXXX copies and give you the message. You can to reset the machine - this might help. Good luck!
Nov 16, 2005 | NEC Nefax 655E Plain Paper Laser Fax
Samsung SF-560 Plain Paper Laser Fax Logo
519 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
