Question about Vtech Cordless 6041 Phone
VTECH 6042 (DECT 6.0) SPEAKERPHONE
Speakerphone on main unit stopped working. The speakerphone button lights up when depressed, but that's it. The speakerphone on the 2nd unit works great. Almost the same - only I don't have a second handset. If I press the speakerphone button, the handset lights up but that's it - I don't have the dual handset
  • 1 more comment
  • Anonymous Sep 12, 2008
    mine is broken to
  • swanna21 Oct 01, 2008
    i have the same problem , the speaker phone lights up but seems like speaker feature is nor working
  • hsag Oct 03, 2008
    When I hit the speakerphone button, it shuts the phone off on both handsets.
5 Suggested Answers
  • 4 Answers
SOURCE: registration
I'm not sure from your description exactly what your problem is, but I have the 28112, and it has a handset menu command for registration, and one for deregistration. If this sounds similar to yours, I'd suggest trying the registration command. If that fails, try deregistering, and then try to register again. I've also heard that these units somehow reset after 20 seconds in the recharge cradle, but I haven't seen that actually appear to work.
If you have problems getting the menu command to work, write back with more info and I'll see if I can figure it out based on what my phone does.
Posted on Jan 28, 2008
  • 5 Answers
SOURCE: avaya 2410 speakerphone
If the phone programming has been set to 2-way and you have reset the phone. Either by unplugging it and waiting for a few minutes then plugging it back in or from the idle state press the "MUTE" key and then dial R E S E T on the keypad. If after this it will still not work as 2 way then it is most likely a faulty phone.
Posted on Feb 11, 2008
  • 4 Answers
SOURCE: GE Model 28118 Series Slim
Did you pick up your voice mail message?
Posted on Dec 28, 2008
SOURCE: model 28111 series dect 6.0 GE phone
I'am subscribed to three way calling from my phone company, but forgot which button to push to connect three way call on my phone is it the green talk button that is in the middle of my phone.
Posted on Feb 17, 2010
  • 98737 Answers
SOURCE: Does the vtech dect 6.0
Some VTech DECT 6.0 phones do, some don't. Without knowing the model of yours, I can't give you a definite answer.
If you need a manual, enter the model number of your phone into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
Posted on Sep 23, 2011
Speakerphone
Nothing to "set up", just push the button with the little speaker symbol on it when you want to turn on speaker phone use.
Apr 23, 2014 | Vtech DECT 6.0 Digital Cordless Phone
How do I fix the speakerphone on a Uniden dect 6.0
check headphone socket, clean & some heating. or" find switch connection & that have short pin & open it.
May 29, 2012 | Uniden DECT 6.0 Cordless Phone ID
V tech dect 6.0...both my handsets die out when i go to use the speakerphone..Is it time to replace the batteries as I've had these phones for over two years now?
Try to fully charge them first and check for how long do they keep charge. But, yes, for some batteries 250-300 recharge cycles is a life span.
Nov 23, 2011 | Vtech Cordless 6041 Phone
Speakerphone does not work
Did you test it before you buy?
Or contact telecom service for help
electronics wholesale
Nov 09, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Phone turn off when speaker is turn on and it disconnect when it turns off
If it is the handset speakerphone, this usually means the battery is dying. The speakerphone uses more power than the regular phone, so when you turn on the speakerphone with a weak battery the handset will shut off and disconnect the call. You likely need a new battery.
Mar 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Does the vtech dect 6.0 have a speakerphone component?
Mar 12, 2011 | Vtech Lands Phones
Using the speaker on the base to make/answer calls
Unless your model specifically says it's a speakerphone, you can't do that. The base mic and speaker are only there for recording your outgoing message and listening to your messages. If it is a speakerphone, there should be a button on the base to activate it.
You can find manuals and other information about your model at Vtech's site.
Mar 11, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Sony spp-s2730 speakerphone on base unit
Saw this once with a bad speaker and another time the reset process shut something off....
It's been about 6 years... sorry...
AL
Jul 17, 2008 | Sony SPP-S2730 Cordless Phone
Model 28111 series dect 6.0 GE phone
Apr 30, 2008 | GE 28111 Cordless Phone
Vtech Cordless 6041 Phone Logo
191 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
