Question about RCA RCR412C Remote Control
Won't work work first time and then lost it again
    Problem Solver:
  • 12 Answers
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Jul 20, 2008
Bluetooth won.t connect
You may need to pair the bluetooth again as it may have lost its pairing id sync.
Delete the pairing if it exists and start from the beginning.
Apr 18, 2014 | ASUS MeMO Pad HD 7
95 Ford Taurus SHO 3.2 stalls randomly
On one of the occasions when it won't start back up, someone will need to figure out if you have lost spark to the plugs or fuel to the injectors to be able to troubleshoot the problem.
Sep 26, 2012 | 1995 Ford Taurus
Sometimes it won't start
Sounds like you may have a starter motor going bad. When they start doing this it is because there is a "bad spot" on the motor armature. It will continue to work each time until by chance, it just happens to stop in that same place again. Usually, it gets worse over time where it starts happening more and more often as more bad spots start to develop on the armature. Then eventually, it gets to where it won't work at all. Disconnecting the battery is probably not doing anything to help you get it started, That is probably just coincidence.
I also would not recommend continuing to disconnect the battery. If there is something else wrong (not the starter motor), it is probably setting a code in the computer. Disconnecting the battery can clear the computer memory and cause this vital information to be lost. You will need this information if you are going to figure out what is going on.
Also, every time you disconnect your battery, your adaptive fuel trim, idle control, and adaptive transmission shift information gets lost. Then when you reconnect the battery, the vehicle can waste a lot of fuel and cause undue wear on your transmission clutches for a few days until it "relearns" this information.
This also causes undue stress and wear on your battery cables that can lead to more serious electrical system problems.
This also causes all of your computer modules to go through a "forced re-boot" every time you do that....anybody that has much experience with a PC at home knows that the best way to destroy a hard drive is to unplug the computer from the wall without properly shutting down then pluging back in again. Files get lost and/or corrupted. If the boot files get corrupted the computer will not reboot at all. Car computers are no different.
Repeatedly disconnecting the battery is just not a good idea.
Feb 15, 2012 | 2000 Mazda MPV
95 mitsubishi manual. Shifting problems. Changed slave cylinder and bled line and it worked perfectly . Today it won't shift unless engine is off. Should I bleed line again? What else might be wro
Check the slave cylinder is coming out when you push the clutch down ,without my head under the bonnet its difficult to say but either you have lost the fluid or the thrust bearing has now pushed through the pressure plate with the correct pressure .
Jan 30, 2012 | 1996 Mitsubishi Galant
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
I lost the manual -- the machine won't take a message even though the default voice message says to leave a message (the machine was bumped off my desk and lost my message and the ability to take a...
Since you declined to specify the model of your machine, pick the model from the list at
http://www.home-electronics.net/ge/pc/user-manuals.asp
Jun 07, 2011 | GE Lands Phones
WD 1tb, lost the partion with the startfiles and now it won´t find the drive. What can I do?
go to computer mangment and u will see drive there in hard disk option
format ur hard drive if u dont have any imp data and it will start working again
Oct 02, 2009 | Western Digital Elements powered by WD 320...
RCA RCR412C Remote Control Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
