How do you change the oil filter on a Hyundau Accent Coupe S reg? How do you drain the old oil and replace the filter?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
CHANGING ENGINE OIL
Be careful not to burn yourself, as the engine oil is hot.
1.
Run the engine until it reaches normal operating temperature.
2.
Stop the engine.
3.
Remove the oil filler cap (on rocker cover) and the drain plug (on the oil pan). Drain the engine oil.
4.
Re-install and tighten the drain plug to the specified torque.
5.
Fill new engine oil through the oil filler.
a.
Cover the generator with a shop towel before pouring the engine oil to ensure that if oil spills, it will not drop on the generator.
b.
Use a funnel to pour in the engine oil.
1.
Filter replacement.
Use a filter wrench to remove the oil filter.
2.
Before installing the new oil filter on the engine, apply clean engine oil to the surface of the rubber gasket.
3.
Tighten the oil filter by hand.
4.
Run the engine to check for engine oil leaks.
5.
After stopping the engine, check the oil level and add oil as necessary.
Filter Selection
All Hyundai engines are equipped with a high quality, throw-away oil filter.
This filter is recommended as a replacement filter on all vehicles.
The quality of replacement filters varies considerably. Only high quality filters should be used to assure the most efficient service.
Make sure that the rubber gasket from the old oil filter is completely removed from the mating surface on the engine block, before installing the new filter.
