Question about Gateway FPD2275W LCD Monitor
Monitor get heated
Sir, my monitor is heating abnormally even for few minutes(15 to20).one day my ups got a buring smell(very less) i immediately switch off my system.after that day i feel my moniter is heating continously,please help me sir.
  • j4jan Oct 25, 2008
    Our sanyo does the same thing. The TV shuts off after about 1/2 hour.
  • 40 Answers
What type and brand is the monitor?  LCD, Plasma, or CRT?
srich
Posted on May 23, 2008
RHEEM RGLG-05EAUER Occasionally, on startup, there is a fair gas smell from the vents for a few seconds.
I think I'd have it checked for a bad heat exchanger. At the very least, make sure you have working Co2 detectors on all levels of the house. You should not be smelling gas from your hear ducts. This is not normal. If anyone in the house is developing a head ache, that would indicate a heat exchanger problem.
Nov 20, 2016 | Heating & Cooling
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
2002 ford escape periodically over heating
Check the thermostat and the fan too. Overheating nothing to do with the heater core, even if you shut the heat off, the car should not overheat
Mar 20, 2013 | 2002 Ford Escape
Sceptre
ur fan is out causeing it to over heat do not turn on computer till fan is repaired so that no chances of buring the board is possible
Feb 15, 2012 | Computers & Internet
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Replaced bad thermal cutoff on Whirlpool dryer LEC6848an with new kit FSP 279769 (cutoff & t-stat). Also, cleaned duct, vent, chute, etc. Heats now, but had to shut it off after a few seconds due to...
It is common to have a slight burning smell in the dryer immediately following a clean and inspect of the cabinet. Although you may have cleaned the dryer cabinet interior and the ventilation ducting, dust particles often get stirred up and will settle on the heating element. These small particles will eventually burn off and should not create any hazards to the operation of the appliance. Allow to run for a few minutes and monitor. The smell should go away.
Apr 18, 2011 | Whirlpool Dryers
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Gateway FPD2275W LCD Monitor Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
