Question about GE AJCQ08ACB Air Conditioner
How to reset
I cleaned it and now it will not cool the compressor does not come on
  • edrica Jun 10, 2008
    i would like to have my airconditioner set at 75 degrees, but every time I lower the temperature, it automatically goes back to 82 degrees, I have tried many things but it stays at 82 degrees, please help
  • 20 Answers
Try your thermoststat
Posted on May 27, 2008
How to reset refrigator
Try making sure the compressor is clean from dust and lint buildup using a vacuum. That will allow the compressor to begin cooling again.
Mar 03, 2015 | Refrigerators
My U-Line beverage cooler is indicating an E5 error code and the unit will not get cold. What is this telling me?
I am not familiar with this unit but in guessing but I would not assume the thermistor is bad, actually if as you say the compressor is running that is all the thermistor can do. My first guess is the condenser needs cleaning, that is the area where it gets warm. If that is clean then the possibility of a refrigerant leak is there. If not that then the compressor most likely has a bad valve in it. I would suggest contacting a refrigeration tech after everything has been cleaned and it still does not cool.
Dec 19, 2014 | ULINE U-Line 1175BEVS-00 1000 Series 24"...
Ro@hotmail.comtemp fridg& frezer will chang 30 to 40 degrees if you open either door it will take a long time for for temp to drop
The compressor is the part which cools the refrigerator.---------- First i will explain the working procedure of your sanyo refrigerator.---------- In the refrigerator, there is a part called compressor, the compressor is the part which cools the freezer section, When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold.--------- So the freezer section cooling/ freezing is must.If freezer is not getting properly cooled or not getting cooled, then fridge section will show the low or no cooling problem.--------------
In your refrigerator, its quite possible that compressor is got weak, nor complete faulty but little bit weak.So when you open and close the fridge or freezer door , the compressor is not that strong to maintain the required temperature.So its working hard to cool inside temperature, but its not doing it quickly as it should.---------.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- ----------------
There is manual reset procedure, sometimes the ice gets frosted all over and blocks the ventilation's for cool air to pass from one section to another, and this also causes problem.So directly going for compressor inspection, before that you can try manual reset procedure and see if that helps.---------
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked. -------- This should help. Thanks.Helpmech.
Aug 22, 2011 | Sanyo SR-3620 Compact Refrigerator
It is not cooling at all just blowing hot air i have cleaned the coils they were dirty is there a reset button that i may need to reset
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Refrigerators
The compressor will not kick on i took the cover off and the compressor is hot will it reset it self or is there a reset button on it somewhere it was running fine just 1 hour ago any suggestions
it has an overload on the compressor that has kicked the compressor out and will not let it start back up,,,let it cool for a bit then try again it will reset it's self,,,,, make sure that both sets of coils on this unit are clean....you see the condensor coils when your on the roof with the cover off... check the inside evaporator coils as well..... let me know what you find out......
May 10, 2011 | Dometic Rooftop RV Air Conditioner
Amana PTAC unit will not cool or heat. Tried reseting, checked supply voltage, ohms checked the heating element, voltage checked off of circuit borad (power everywhere except the two heater terminals)
Compressor working ?
Please follow this tips:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Please specify, if any error code..........
Thanks. Helpful?
Jan 19, 2011 | Heating & Cooling
My frigidaire model GHSC39EGOB0 does not cool at all. I noticed the fan got stuck with the wires. I fixed it but still the same problem.
After fixing the fan, you may have to unplug the unit and then let it cool down before the compressor will start again...there is a thermal overload on the compressor that will need to reset....
It is possible though that the compressor got too hot a is ruined or that the start relay and capacitor are fried because of the fan stoppage. Let the unit cool down and them if the compressor will not start then check out these tips. They will give you more info on the compressor situation...
RefrigeratorCondenser Coil Cleaning Refrigerator Repair
heatman101
Sep 15, 2010 | Refrigerators
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
May 12, 2009 | Refrigerators
Refridgerator is not cooling or freezing
If the compressor comes on, then it is most likely working, unless it makes a loud humming noise. However, if it makes a clicking noise, it could have a bad relay. If the compressor gets too hot, it will shut itself off on overload until it's cool enough to run again, which is usually long enough to defrost your food.
You may have a problem in your sealed system. If this is the case, there may be a refrigerant leak somewhere. If this is the case, you should have a technician come out. Your sealed system should be covered under warranty if your refrigerator is under 5 years old.
Please let me know if you have any other questions about this.
Mar 10, 2008 | Refrigerators
GE AJCQ08ACB Air Conditioner Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
