Question about Sony VPL-CX75 Multimedia Projector
Will not turn on
My sony vpl-cx75 will not turn on.i put in a new lamp still nothing the power light is red when i first plug in but then goes out a few minits later
    Problem Solver:
  • 13 Answers
I have just solved this problem. The solution for me was a capacitor in the second PCB of the primary power supply. The Cap was a 2200uf @ 10 volt. Once I replaced this the Projector powered up fine.
Posted on Apr 14, 2009
  • 1 more comment
  • liamrices1
    liamrices1 Jan 18, 2013
    have you a wiring diagram as i think i have the same issue
  • liamrices1
    have you the wiring diagram as i have the same issue
  • Digital Recovery Dec 30, 2013
    No, I don't sorry.
I have the exact problem on the exact same model .
HELP ... I have been told it may be a problem with one
of the power supplies on board ??? is this a red herring ?
Posted on Jun 20, 2008
Sony Data Projector VPL CX75. No input setting available from menu
This may or may not be the solution to your problem, but i'll let you know anyway. Input settings are only accessible when you have a signal going into the projector. This is because the input settings are for adjusting the signal, therefore if there is no signal there is nothing to adjust.
Mar 25, 2011 | Sony VPL-CX75 Multimedia Projector
No power light if bulb is bad? plug unit in the fans don't work and no power light.
Check the internal fuse since power is not flowing into the projector and the chord too, which could have been damaged ..........sodeep
Nov 10, 2009 | Sony VPL-CX75 Multimedia Projector
Projector will not turn on
are there any led lit or flashing? this will say if there is a problem and let you know what it might be. there may be a power supply issue, a cooling fan issue, or a lamp issue that will make the projector shut down by itself.
Aug 05, 2009 | Sony VPL-CX75 Multimedia Projector
Not producing any image
check the Lamp unit. If Lamp is ok then check the ballast unit
Mar 10, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony projector
Hi there
Check if your lamp is blown by taking it out and looking for any marks or discolouring on the inside of the lamp.
If the lamp looks fine , it could be that your Ballast ( lamp's powersupply ) is faulty.
Dec 13, 2007 | Sony VPL-CX75 Multimedia Projector
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-CX75 Multimedia Projector Logo
572 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
