What is the best technic to adjust the colors on my TV
I get a new LCD TV Samsung LN46A530 I've been able to installed and very well except for the colors. I tried to adjust the colors but either the colors are to hot (reddish) or to cold (blueish), and the greens look faded, except those showing up in the faces...
Any way, this tv have so many settings that I'm not sure where to start.
What I need to do to adjust the colors efficiently?
  • Anonymous Apr 18, 2009
    Our new Toshiba 40RV52U setting from the factory isn't true to color and much to dark. I have heard of a web site that gives one settings for their model number. Does any one know it? Thanks
    Sergeant:
  • 280 Answers
The easiest way is ... from the menu set all video to default. if there is nothing wrong with the set it should look normal.
Posted on May 23, 2008
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Samsung LN46A530 turn tv on green hue appears
It sound the the panel is faulty. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 13, 2013 | Samsung LN46A530 46 in. LCD HDTV
My 42 in Samsung (LN46A530) TV is flickering when I turned it on and it stays for a very long time.
A lot of the Samsung's have a common issue, there is a jumper in the power supply that needs to be removed, Contact Samsung with the model number and they can tell you if your set is one, they were fixing this issue for free.
Dec 14, 2012 | Samsung LN46A530 46 in. LCD HDTV
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
Jun 09, 2011 | Samsung LN46A530 46 in. LCD HDTV
I just purchased a Samsung Multi function color laser CLX-3175FW printer. It prints very light graphics. Eventhough I've set it to print graphics to the best setting, this doesn't help. The...
if you installate the printer you will find the Samsung (Blue) Logo with one watch in your taskbar on the bottem of your screen, double click on this icon, in the new windo click on Printer Setting then on color now you see an buttom "Color Adjustment" click on it, in the new window you can adjust your color via a slitswich for each color, try how you like your printout best.
May 10, 2011 | Samsung CLX-3175FW Multifunction Laser...
What is causing my TV to display inverted colors, like a negative photograph? The picture of my LN46A530 LCD TV has degraded an it looks like if I was seeing a negative photo.
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Thanks.
Mar 03, 2011 | Samsung LN46A530 46 in. LCD HDTV
Samsung lcd ln46a530 is having some difficulty turning on and when i does turn on the picture drops out( blank) but the sound stays on.
The tv have 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbihes 2 long LCD inverter boards for the replacement.
Oct 27, 2010 | Samsung LN46A530 46 in. LCD HDTV
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
I own a samsung ln46a530 and need to configure it for the best picture.....any recomendatios?
If you haven't already bought a nice set of HDMI cables, go ahead and do so (just dont fall for the "gold plated" cables as they are a gimmick). Unfortunately, while we all want that HD quality, there seems to be some problems with the ln46a530 when switching from RCA to HDMI. On the bright side, they have been resolved in this forum post.
Best audio settings:
Mode: Custom
SRS TruSurround XT: On
Auto Volume: On
TV Speaker: On
(# of clicks):
Balance: 0
100Hz: 8 clicks right
300Hz: 8 left
1kHz: 4 left
3kHz: 3 right
10kHz: 5 right
For best picture:
Most accurate settings
(This with the mode at movie)
Backlight = 6
Contrast = 85
Brightness = 49
Sharpness = 0
Color = 50
Tint = G50/R50
DETAILED SETTINGS
Black Adjust = Off
Dynamic Contrast = Off
Gamma = 0
Color Space = Custom
Red: R33 - G0 - B0
Green: R18 - G52 - B0
Blue: R11 - G0 - B51
Yellow: R49 - G53 - B0
Cyan: R22 - G46 - B56
Magenta: R37 - G0 - B43
Flesh Tone = 0
Edge Enhancement = Off
Xycc = Off
WHITE BALANCE
R-Offset = 26
G-Offset = 25
B-Offset = 22
R-Gain = 30
G-Gain = 25
B-Gain = 25
PICTURE OPTIONS
Color Tone = Warm 2
Digital N/R = Off
HDMI Black Level = Low (actually it's disabled when playing Blu-ray)<-- set this according to your source! If you use a PC, or aPS3/Xbox360 with expanded RGB levels, you might need to set this tonormal!
Film Mode = off (disabled)
Blue Mode = Off
Energy Saving = Medium
Entertainment modes = Off
Hope this helps!!
Dec 01, 2008 | Samsung Televison & Video
Open Questions:
Televison & Video Logo
622 people viewed this question
Top Televison & Video Experts
Electro Med Services...
