Question about Toshiba 42H81 42" Rear Projection Television
Shaking picture I have a 42 inch Toshiba. If it had been turned off for a period of time, the picture shakes when you turn it on. It takes about 30 minutes to warm up and then the picture is fine. The time that it takes to warm up is gradually increasing. I have been told it could be the colour bulbs and if it is, it will cost more to repair than to replace. Any ideas?
    Genius:
  • 1,030 Answers
Yes.. i repair about 2 of these a month here at the shop. Toshiba has issued a service bulliteen concerning these. What the problem is a cuircit board called the "hypermodule". THere are 11 very very small surface mounted capacitors that have to be replace. Ideally the module can be replaced... more expensive but not by much considering labor is intensive on the capcitors .. but here the trouble... the board is not availble. we charge about 450 for this repair.. the boards not easy to remove the u have to be an expert solder to get these cap off an on.. i personally damaged a couple boards and like i said. boards not availble ...here is a picture of the board the caps are the small circular components. willie@fordtv.com
Posted on May 23, 2008
Theres a rattling sound in my tv,i dont know what it is
HAHAHA Melissa shaking a TV is not the way to find out what the problem is take it to a repair shop for an estimate then decide if buying a new set is better than repairing
Nov 22, 2015 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
it's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Dec 09, 2012 | Toshiba Televison & Video
Toshiba 30HF84 Picture Doubling and Shaking
Check its main power regulator section for any faulty capacitors.
Sep 01, 2012 | Toshiba 30HF84 30" TV
The screen is shaking horizontally. It does this when I first turn it on and gradually gets better after about 30 minutes. There are also 2 or 3 vertical lines going side to side while the picture is...
42H83 is a Toshiba first made in 2003.
What is wrong (98% chance) is the HYPER BOARD in this set is now failing----all signal from all inputs is processed thru this board.
Considering the board is now only available on a rebuild basis----and the cost for this is well over 200 dollars not counting labor to remove--replace--set, unless you know someone who is VERY GOOD AT SOLDERING-----not worth repairing.
What happens here is this board has close to 20 surface mounted filter caps---with time and heat they dry out---usually the time before the problem clears up will get longer and longer---leaking caps may start to function to some degree after they get hot--hence the time from dead cold until the set works.
Most caps have 2 leads and are soldered through the circuit board----these are very small caps with tabs on them----and are soldered to the top of the board.
I am sorry to give you not so good news--but based on your description---I am sure it is your problem.
Call around your area telling them model number and you suspect it is a bad HYPER board---if a shop can actually fix it(replace the caps) parts cost would be under 30 dollars---
Any authorized Toshiba repair shop can go online and see the service bulletin for this--they have a large color picture of the board and indicate which caps have to be replaced.
If this information helped you, rate this solution as I do this here for free.
If you have questions or want advice let me know--I am here to help people.
SD TECH
Nov 07, 2009 | Toshiba 42H83 42" Rear Projection...
My toshiba 42h83 has a shaking picture with a 2 to 3 " green stripe at the top of the screen. How can I fix this?? thank's Karl
Check all wires cables go to the tv,shakes,jiggles might,see the prob.than change the wires cables.Not wires cables,than ur main video board is the prob.must change.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Shaking lower half of the screen worsens with time on
Hi, Suggest to take to a local Tv Repair Shop. Thanks.
Sep 22, 2009 | LG 42PC3D 42 in. Plasma Television
Toshiba Laptop with flickering screen
its a faulty screen. i would call samsung or go to their website and have it fixed.
Jul 25, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
TV picture shaking!!!
You have a Hyper module problem.Very common with these chassis.Toshiba part # 23148024.This part is no longer available,but it can be repaired.I dont know how much electronics training you may have but it`s a pretty detailed job.The hyper board is the silver stand up module inside the unit right behind the external Audio/Video jack panel.There are 11 little capacitors that all need to be replaced.The value of these caps are 10uf @ 16VDC.I do this job for about $245.00 and the unit works fine.Check with your local shop if it is too much for you.If you don`t know what you are doing you can ruin this module then it`s time for a new set.Good luck.
Jan 15, 2009 | Toshiba 42H82 42" Rear Projection...
Horizontal Shaking lines on picture
make sure the cable ord in the back is plugged in right
Dec 11, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
