Question about Cameras
Sony Cyber-shot DSC-T9 error 62.10 - Cameras
    Guru:
  • 1,342 Answers
This is a memory stick error.
Click HERE to download your User's Manual and Troubleshooting Guide.
Posted on May 24, 2008
  • 1,031 Answers
A camera malfunction has occured remove the power the battery after some time say 30min after then initialize the camera then turn the camera on again
    President:
  • 2,712 Answers
This is due to a power issue. Try a reset of the camera. Your camera may have a reset button. If present, try pressing that. If not, try a hard reset:
Remove the batteries from the camera, also any SD Card that may be there. Wait about 2 minutes, reinsert the batteries and SD card and power on and see if the issue persists (you may want to use fresh batteries as well..)
If the issue still persists, then I'm afraid you may have to take it in for servicing, or contact Sony support. I believe they have a provision for live chat. You can find chat here:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=DSCT9
Scroll to "Cameras, Camcorders and Digital Imaging Products" and click on the chat button.
Or you can call them:
In English: 1-800-222-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
  • 156 Answers
I know this sounds crazy but if its a zoom error the lens is stuck... Whack it on a table slightly see if it free's the lens up. I'm serious... not too hard though.
    Sergeant:
    Champion:
  • 304 Answers
have you dropped the camera before..?
  • Elizabeth Krijt
    Elizabeth Krijt May 24, 2008
    hit it on the battery side of the camera's case, or try to remove first the camera battery..
  • Elizabeth Krijt
    first put out the battery from camera, then put mode picture and then
    a
    little hits in each side from the camera, and now you put the battery inside the
    camera,
    put on the camera...
    and EUREKA !!!!!!
    the message is lost!
    Brigadier General:
  • 6,966 Answers
Sony Error Code 62.10 indicates power problem and could be the battery, internal memory battery or AC adapter. Try checking aforementioned items and/or try a manual reset.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 24, 2008
    In some instances, it could be that the battery terminals are corroded to the point that the batteries are no longer making good contact. The same could also hold true with the memory stich contacts.
4 Suggested Answers
swami nathan
  • 208 Answers
SOURCE: Sony Cyber-shot Error Code E:61:00
you may have these symptoms,
Symptoms :
  1. After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  2. Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  3. Zoom in and zoom out would not work.
  4. Playback mode and the Setup mode was not affected.
To fix this problem,
Do these...
A) Put the camera about a half inch from a hard surface.
B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
A) Turn it on and let the lense go out fully
B) See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed!
If not, try these steps a few more times. If still nothing, then I suggest you to call Sony, but this DID work for 90%, so hopefully it''ll work for you :)
Thanx for using fixya,
Cheers.
Posted on Sep 27, 2008
masteria
  • 355 Answers
SOURCE: replace Sony Cyber-shot DSC-W55 shutter button
Don't throw your Sony Cyber-Shot camera away!
We found a website who has created an entire comprehensive photo instructions for the Sony Cyber-Shot DSC-H Series Shutter Button Installation.
They also have the Sony Cyber-Shot DSC-H9 Shutter Button Installation Instructions as well!
Please note that we STRONGLY recommend using a flash discharger. This is for your safety and also for your camera's safety.
Hope this helps to get your camera working and start capturing memories again!
Posted on Aug 18, 2009
Rammsteins
  • 300 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
The region has to be changed to US or UK. It is done with a special Sony adjustment software.
Posted on Mar 05, 2011
Hi I lost my cable for Sony cyber-shot camera DSC- T9. I want transfer some photos to my laptop and I can't.Can I buy the same cable and if yes can you tell me which one??? number or something please
You're better off buying a card reader instead, if your computer doesn't already have one. It's likely to be faster and easier, and you can continue to use it if you get a new camera.
Jan 02, 2017 | Sony Cyber-shot DSC-T9 Digital Camera
How do i charge my cyber-shot dsc-t9
You should be able to plug in the USB cord that came with the camera. Connect the one end to the camera then the other end to a USB wall charger or your computer. If you no longer have the USB cable, you can purchase one here from Amazon.
May 03, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
On operating my sony DSC-T9 Cyber-shot camera, the display is blured and an error massage says: E:62:10. What can I do to solve the problem. Thank's Yoetz Deutsch
Gently hit the camera on the side by the battery case this may resolve the problem. If not then it will have to go in for repair.
Good luck.
Jan 06, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
Hi my camera screen is broken its model no is sony dsc t9
LCD replacement part number for DSC-T9 is as follows..
A1166629A... SERVICE, LCD BLOCK ASSY
Available in Part Store for $72.95
Thanks.
Jan 10, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Sony DSC-T9 camera scrren blurry after drop
I'm sorry to say that you'll probably be able to replace the 6MP camera with a better one for less than the cost of repair, even if attempting the repair yourself.
Sep 03, 2009 | Pentax Optio S50 Digital Camera
Access to menu on sony cyber-shot DSC-T9
You can download Instruction Manual / User Guide of DSC-T9 from Sony Support and will get to know every thing about this camera.
Jan 07, 2009 | Sony Cyber-shot DSC-T9 Digital Camera
Sony cybershot dsc t9
E62:10 shows error in "angular vilocity sensor peripheral circuits" ,according to service manual. If you know how to open this camera, go ahead and remove and reinsert flexible wires / ribbons. Hope problem will be solved.
Aug 08, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Sony cyber shot t9 slide show music turn off
When I turn my Syber shot 6.0 mega pixels on it shows only a white or dark display. The fotos taken are the same. It seems that something is not opening the lens. What is the problem and how can I fix it?
Many thanks.
Mar 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
205 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
