Question about Sony Audio Players & Recorders
COMPACT DISC PLAYER
The carousel doesn't always open when you push the button. When that happens if you give it a rap on top the carousel will revolve as if selecting a disc to play and then stop. If you push the open button again, then it will open. Once in a while it will get stuck while playing a disc and won't move until you give it a rap.
  • 4,234 Answers
Please update this with the make and model so I can assist.
Thanks,
Dan
Posted on May 23, 2008
Sony Compact disc player CDP-c705 carosel will not open
There may be a disc stuck inside but carousel-type CD changers are trouble-prone.
Jun 20, 2014 | Sony Audio Players & Recorders
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Player was moved discs fell forward. Now when the player comes on it makes a horrible sound. Can't get door to open
you're going to have to open the player by removing the top cover and returning the discs to their correct places on the carousel. If you've coded the discs' locations and disc names it will be a pain to have to re-code them, I don't know if the memory will clear if you take the discs out and power the unit up and it finds they're not there.
I believe the discs being out of place are what is preventing the door from opening. It's operated by a motor located under the right front of the carousel, and the only way to get it it is to remove the carousel.... which isn't hugely easy but it can be done, you'll have to take the top stuff off inside, unplug at least several of the cables etc so you can move the top board out of the way. Make sure that all the discs are back in their places on the carousel, OR removed, before you turn the unit back on.
Dec 02, 2010 | Sony CDP-CX400 400-Disc CD Changer
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Dec 15, 2007 | Sony CDP-CE375 5-Disc CD Changer
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
96 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
