Question about Texas Instruments TI-83+ Graphing Calculator (TEX83PL)
TI-83 battery change
I changed the batteries (AAA) and now the screen is dark. Nothing will display.
HELP!
  • rllaney Nov 30, 2008
    I changed the batteries on my ti-83 and now the screen is completely dark and doesn't respond when I try to adjust it.
  • Dick
    Dick May 11, 2010
    Your contrast setting has changed. Consult your manual to lighten it and your screen will be viewable again.
SOURCE: i replaced 4-AAA batteries with
I'm not sure what type of batteries you are using, but if they are Lithium (i.e. Energizer Lithium, for example), I've seen Lithium batteries cause issues with some of my electronic gadgets. I cannot use the Lithium(s) in my blood glucose monitor, for example. The screen looks solid black when I try to - so I have to use Alkaline batteries. :(Hope this helps in some way!
Posted on Jun 30, 2009
  • 7993 Answers
SOURCE: Screen went blank replaced AAA batteries starts up
You may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Posted on Oct 29, 2009
  • 102366 Answers
SOURCE: My TI-83 Plus turns on
Try turning the contrast down. Turn the calculator on. Press and release the 2ND key. Press and hold the Down-arrow key for a few seconds until the screen lightens.
Posted on Mar 09, 2010
  • 7993 Answers
SOURCE: I put new lithium triple
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Posted on Sep 06, 2010
doron_c21
  • 387 Answers
SOURCE: My TI-83 Plus Graphing Calculator
check the I/O port
or maybe one of the keys is stuck
hope it will help
Posted on Nov 27, 2010
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My TI 83 plus is not working. when i press"on" nothing happens. I changed my AAA batteries, i even change the back maxwell battery, but nothing happened
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 27, 2010 | Texas Instruments TI-83 Plus Calculator
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
I have had the TI-83 Plus Silver Edition for about 6 years and haven't used it in 3 years. Once I changed the batteries, it worked fine. Lately, it has been putting numbers in upside down or not at all. I...
I hope that there is a way to fix it. If you have been playing some 3rd party games, there is no telling what they can do to your calculator. But at least it is showing some thing and that augurs well.
The fisrt diganostics you should perform are:
  1. Make sure batteries are good and inserted correctly, respecting the polarity diagram: Yes, I myself made this mistake and it must be ruled out before doing anything else.
  2. After a change of batteries, the screen contrast can change: It may become too dark or too light. If it is too dark, you would not think about a malfunction because you see something on the scree. BUT it the screen is too light, it is easy to conclude that there is a malfunction because you do not see what the calculator is doing after you press a key.
  3. So, the second measure is to adjust the contrast. Press [2nd] key and Release it. Then Press and HOLD the UpArrow until screen is dark enough.
  4. A third easy measure is to use the TIConnect software (available on education.ti.com) to retrieve the device Info, and if calculator is recognized to reinstall or update the OS. You need a TI USB SilverLink cable.
Here are some more procedures to perform in the order they are presented. Please read the post till the end.
A
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. the calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
B.
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary. (see above)
C.
This step requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. the calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI web site.
  • An I/O cable to connect two calculators through their I/O ports.
Mar 10, 2010 | Texas Instruments TI-83 Plus Calculator
I have no power to my ti-83 plus, I changed batteries and the backup battery is still good
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
C. Third option
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 22, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83 isnt turning on after i changer all the batterys
C. Third option
D. Last option
Hope it helps.
Nov 21, 2009 | Texas Instruments TI-83 Plus Calculator
I own a TI-83 Plus that just quite one day. I replaced the battery and still nothing. The display never recovered. Between my son and daughter and I this is the third TI-83 Plus that has had power circuit...
C. Third option
D. Last option
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Nov 19, 2009 | Texas Instruments TI-83 Plus Calculator
When I turn on the Ti-83 the screen comes up in all grayed out and can't do anything except turnoff
C. Third option
D. Last option
Hope it helps.
Nov 16, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
409 people viewed this question
Top Texas Instruments Computers & Internet Experts
Bapco
Steve
Are you a Texas Instruments Computer and Internet Expert? Answer questions, earn points and help others
