Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Cant connect my WL520GC wireless router
I have an Iconnect 622 modem and everything I have have tried dosent work
I am buying the ASUS 4G machine and have a USB router connecting to Vodaphone through the molbile network. Without installing Windows XP can I connect the wireless modem to the little computer. Cheers Nick W
Posted on May 26, 2008
Ipad dosent see it
Do you have any other wireless computer or device in the network?
Can you connect to the wireless network on any other wireless computer or device?
Try changing wireless channel on the router.
Make sure that SSID broadcast is enabled.
How to connect to the wireless network on iPad
Apr 22, 2012 | Hiro (H50188) Wireless Router
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can't connect to the modem
If you have a Cable Modem try doing a MAC cloning on the router and check the Firmware update, if you have a DSL connection try changing the LAN ip Address (Eg:- from 192.168.1.1 to 192.168.2.1) or if you have PPPOE then use the correct PPPOE username and password on the router and try to set it up, if that dosent work then we will take it from that point.
Mar 16, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Cant connect ps3 to wireless router. tried everything.
try re setting the router/modem.. and then power on the PS3
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I tried everything , i hooked up my new router to my modem and begin to set it up and when it came down to connect to the internet it didn't and it said to reboot my modem and i did and it did nothing and...
firstly, go and reset your router again. Then try to set it up again with your manual. Are you 100% sure that all the settings are correct? If so, enter them and everything should work ok. If not, try contacting your internet provider, if there is any special settings you need for your modem to work with your router.
Oct 15, 2009 | Linksys Wireless-G WRT54G Router
Dlink wireless wbr1310 connection problem
Try this,
Shut down everything starting with your computer, then the router, then the modem.
Wait 30 seconds. Restart everything in this order:
Modem first (wait for all the lights to come on) then start your router (again wait till everything lights up and settles down) finally start up you computer.
Check to see if you can connect to the routers control panel which is usually 192.168.2.1.
In the control panel there should be a place to enter your computers MAC address, usually under MAC Address Filtering. To find the Mac Address of your computer, go to Start/Run/ when the window opens type CMD and hit enter.
A Dos window should open, type in the following. ipconfig -all
It should then display your Mac Address which you will want to write down so that you have it ready to type into the Mac Address filter .
After entering all the info. Restart everything just as I instructed in the beginning and you should be good to go.
Sep 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have a buffalo wireless router, and cant connect it properly, i put the cd into my pc to tell me how to connect everything and it doesnt work
hi,
After connecting your router hardwired.. do the ipconfig in the command prompt window... make a note of your default gateway...It should be as 192.168.1.xxx Enter this no... in the address bar in Internet Explorer... Access the Modem... Try to configure it with the username and the password provided from your ISP, eg bell, verizon, primus etc..
this is the manual installation of your wireless router.. make sure that the modem is in the bridged mode or DHCP mode...
was i helpful?
Nov 22, 2008 | Uniden WNR2304P 802.11b Wireless 4-Port...
I am connected to the net via a iconnect 625 wireless modem / router, it puts out a weak signal to my wireless LAN and I have connected a TP-Link wireless router onto the iconnect. windows tells me i am...
You should only use 1 DCHP device
try and reduce your router to 1 only and use a access point for your wireless not another router they will try to give each other an IP
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
251 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
