Question about Sharp Audio Players & Recorders
Mini disc player will not read disc - Sharp Audio Players & Recorders
  • 4,234 Answers
Minidisc player is just a small version of a CD player and has the same types of issues. Either the lens is diry or the optics are failing. Try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, the optics assembly will need to be replaced.
Dan
Posted on May 23, 2008
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Read error c13
It cannot read your disc for some reason... Bad disc, recorded in an extended format by a higher level machine are possibilities...
Jan 02, 2014 | Sony MDS-JE480 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Read error c13
Deck cannot read disc for some reason - try another disc.
Sep 08, 2013 | Sony MDS-JE480 Mini Disc Player
My sony md player wont read HI mini discs
The 480 is not designed to read HI MDs. If I remember right, it can read them as regular discs.
You can always purchase a HI-MD recorder, if that is important to you.
Apr 30, 2012 | Sony 5 Pack Hi-Minidisc 1gb w/Case...
Disc read error
You have a disc read error.
Mar 22, 2012 | Sony MDS-E10 Mini Disc Player
MINI DISC READ ERROR C13
Your deck can't read the table of contents on the Minidisc for some reason...
Oct 01, 2011 | Sony MDS-JE480 Mini Disc Player
Sony MDS-B6P Mini Disc Player doesn't read the disc. Drive motor not turning motor is good. The problem is on the board under the loading mechanism. I swapped boards with another machine and it reads fine....
hello larry_pauley!
please check voltages of motor drive circuit (especially driving transistor), if you still have the working board then you can compare between.
regards
Apr 06, 2011 | Sony MDS-B5 Mini Disc Player
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Mini-DVD playback
two things:
1) connect the camcorder to your computer using a USB cable and play it through that, by the way, what computer is it?
2) you can finalize without the ac adapter - its a built in safeguard to ensure that there is enough power to allow finalization to complete
Jul 18, 2008 | Panasonic VDR-D100 DVD Camcorder
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
