Question about Mpio FY400 MP3 Player
Fy400 when i turn on my fy400 it says IN VALID MEMORY INSERT MBR how to solve this?
    Problem Solver:
  • 5 Answers
Para quien tenga este problema con estos mp3 y todav?a no lo haya tirado, esto es lo que hic? yo el otro d?a que lo encontr? por ah? tirado:
- Quita la bater?a del mp3. - Pulsa los botones de "Func" y "Play". - Sin soltar los botones, conecta el mp3 al usb del ordenador. - Aparecer? un mensaje para formatear el mp3. - Suelta los botones y pulsa el bot?n "Rec". - El mp3 comenzar? a formatearse solo y volver? a funcionar.
Espero que os sirva. Un saludo.
First of all, sorry for my English
If you still have this mp3 or for anyone who sees this solution, this is what I did:
- Remove de mp3 battery. - Press and hold down de "Func" and "Play" buttons. - Connect the mp3 to computer's usb. - A message of formating the mp3 will appear. - Release de buttons and press de "Rec" button. - Formating will start and in a few seconds the mp3 will work again.
Hope it works...
Posted on Nov 20, 2010
BOOTMGR IS COMPRESSED
Validate and Fix the File System
This runs the check disk program to detect and attempt to repair problems on one partition. For example, to repair the C: drive:
At the prompt type chkdsk c: /r
Repair the Boot Process
Typically this is used if Windows doesn't start and you can't get to the safe mode menu. You might also replace the Master Boot Record (MBR) and boot sector if you suspect a virus infection. There are four options:
New MBR - Insert a new generic MBR without changing the partition table.
At the prompt, type: bootrec /FixMbr
New Boot Sector - Insert a new Windows 7/Vista compatible boot sector. It will automatically insert the right type of sector for the file system type (NTFS, FAT32, etc.)
At the prompt, type: bootrec /FixBoot Rebuild BCD - Rebuild the Boot Configuration Data (BCD). The BCD controls which partition boots. This option will let you select which installations to include in the BCD.
At the prompt, type: bootrec /RebuildBcd Find OSes - Scan the system for all OS installations that are compatible with Vista/2008 and will also show those that are currently included in the BCD.
At the prompt, type: bootrec /ScanOs
in the end type in C:/expand bootmgr temp
Aug 24, 2011 | Computers & Internet
Invalid memory can't find mbr is mpio fy400
Hope it works...
Nov 12, 2010 | Mpio FY400 MP3 Player
When I try to turn on my laptop, it will turn on and go to the Asus logo then turn off immediately. I watch the lights and the orange/ green one flashes orange. I have taken the battery and power cord...
first check the AC adaptor is there any output voltage? if yes follow these step:
try to turn on the laptop without the AC adaptor, if it still not power on, remove the memory card and try to reboot, if the problem was not solved reinstall the memory card and remove the hard drive because it can be fautly MBR in your HDD.
Oct 28, 2010 | ASUS Computers & Internet
I just installed Windows 7 I turn off the computer, and when I turn it back on later it said bootmgr is compressed press Ctrl Alt Del
try this,it works for me
play with it a bit,see how u go
Aug 14, 2010 | Computers & Internet
How tp convert a GPT hard drive to a MBR hard drive? thanks
Boot off your Vista disc and go to the Recovery options. Once inside there access Command Prompt (It is a choice in the Menu) type Diskpart.exe and hit enter. Then type Help you will see many options.
What you want to do is type 'List Disk' select the Disk you wish to convert and so forth. Basically the way to convert from GPT to MBR is in there. You can also clean all data off the disk from inside Diskpart and start over with MBR.
Commands to Convert Disks
convert mbr [noerr]
Use the convert mbr command to set the partitioning style of the current disk to MBR. The disk may be a basic disk or a dynamic disk but the disk must not contain any valid data partitions or volumes.
convert gpt [noerr]
Use the convert gpt command to set the partitioning style of the current disk to GPT. The disk may be a basic or a dynamic disk but it must not contain any valid data partitions or volumes. This command is valid only on Itanium-based computers; it may be unsuccessful on x-86-based computers.
convert dynamic [noerr]
Use the convert dynamic command to change a basic disk into a dynamic disk. The disk may contain valid data partitions.
convert basic [noerr]
Use the convert basic command to change an empty dynamic disk to basic.
http://support.microsoft.com/kb/300415
Mar 11, 2010 | Compaq Presario 1692 Notebook
I tried turning my mp3 player on and it said "invalid memory, cant find MBR"
Invalid MBR = Invalid Master Boot Record.
This means that your player Flash Memory drive is corrupted and unfortunately may need to be reformatted if you cannot repair it using some Disk drive or Flash drive utility.
You can try to use 'Properties -> Tools -> Error Checking -> Check now' to fix the issue.
If you have a backup of the music on your player, I would simply use Windows Explorer and FORMAT it using FAT32.
Hope it helps.
Dec 22, 2009 | Mpio FL300 MP3 Player
Nokia 1100 sim not valid
nokia 1208 sim not valid plz solve my problem
Apr 09, 2009 | Nokia 1100
Ntlds missing
ok first u have to try insert the cd of xp and download first driver after the they told u that 2option in one of the option is repair. u chose the repair after command prompt open u chose 1no and u go to c drive and write chkdsk /r u have to run this command.this problem is solve. other wise the problem is not solve u have to again same problme u have to not try the first repair. but u try the 2nd repair the problem is completly solve..
Apr 03, 2009 | Computers & Internet
Para quien tenga este problema con estos mp3 y todavía no lo haya tirado, esto es lo que hicé yo el otro día que lo encontré por ahí tirado:
- Quita la batería del mp3. - Pulsa los botones de "Func" y "Play". - Sin soltar los botones, conecta el mp3 al usb del ordenador. - Aparecerá un mensaje para formatear el mp3. - Suelta los botones y pulsa el botón "Rec". - El mp3 comenzará a formatearse solo y volverá a funcionar.
Hope it works...
Nov 23, 2008 | Mpio FY400 MP3 Player
Invalid MEMORY...help!!
Hope it works... it does in a FY400
Aug 15, 2006 | Mpio FY500 MP3 Player
Mpio FY400 MP3 Player Logo
107 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
