Question about Compaq Armada M700 Notebook
The screem has broken and it can not power on
My compaq armada m700 pentinm 3, has a broken screem but before then it refuse to power on. please can you help me slove the problem
  • 537 Answers
Well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
Posted on May 23, 2008
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Armada m3000 screen
you can mess around and try to fix it but on those old machines its really not worth it(I own 5 of these).Might I suggest the Armada M700 or the E500--e500 is what im on now and it runs better than a brand new dell or compaq)you might get a new screen on ebay for about 40 bucks. It might be a better idea to buy a new one and save the parts from your old one. You can get a new one for 70 bucks on ebay.
http://cgi.ebay.com/COMPAQ-ARMADA-M300-Intel-Pentium-3-LAPTOP_W0QQitemZ200297181300QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Jul 24, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
May 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
May 07, 2008 | Compaq Armada M700 Notebook
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
takecare.
Apr 28, 2008 | Compaq Armada M700 Notebook
Compaq armada M700 power on problem
HMMMMMMMMMMM, SOUNDS LIKE SOMEONE NEEDS A INVERTER! YOU CAN BUY ONE OF THESE ONLINE, BUT UNLESS YOU KNOW HOW TO PUT ONE IN DON'T DO IT.
CHECK TO SEE IF THE DISPLAY WORKS BY PLUGGING A VGA CORD FROM YOUR NOTEBOOK TO YOUR MONITOR IF YOUR MONITOR SHOWS WHAT YOUR NOTEBOOK IS DISPLAYING, THEN IT'S YOUR INVERTER.
Dec 17, 2007 | Compaq Armada M700 Motherboard
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
