Question about Childesigns Hadley Crib 64-715
Lost screws i have the conversion rail to turn the crib into a toddler bed, but have lost the screws and manual. where can i get the right screws or replacement parts
  • 537 Answers
Call Hadley. Do you have *any* of the screws? If you had one, you could go to Home Depot or Lowes and see if you could match them up.
Posted on May 23, 2008
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
I have a europa baby chatham lifestyle crib. color is tea stain. date of production is May 18, 2006. I am looking for a conversion kit to convert from the crib to the toddler bed. where can I locate a...
I know its been a while but if you're still looking for the toddler rail or even the full size bed rails call Lajobi (the manufacturer) at 888-266-2848 or email them at info@lajobi.com. I bought this same crib in 2006 at Baby Depot and I ordered the toddler bed rail through them in 2009 for around $60. Now I'm ready for the full size bed rails but the crib has been discontinued. The manufactuer has a compatible bed rail in the same tea stain for $149 plus shipping.
Oct 12, 2010 | Toys
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
How do I convert from a crib to a toddler bed? Do
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use
Mar 03, 2010 | Sorelle Regal 310 Crib
Delta Martine crib conversion kit
You can order the crib rails through your local Babies R Us. We have the same crib, and have been having trouble locating them also. I spoke with the store manager today, and she said all DELTA cribs use the same rails. They are a metal pair that cost $69.99. The number for them is: 617153. Hope this helps!! :-)
Jan 09, 2010 | Delta Martine Crib
How do i convert my aspen crib into a toddler bed?
Depending on the aspen crib you have,there should have been a conversion rail supplied with it.
You would take the sliding rail off of the crib and put the conversion rail in it's place. This would probably line up with the bottom screw holes.
Hope this helps.
Sep 23, 2009 | Baby Gear
Converting crib to toddler bed
It should have come with the toddler rail when you purchased the crib.  Simply remove a few screws and take the front of the crib off (what would be the footboard).  Then simply slide the toddler rail in the tracks.
A purchase of adult rails is required to make the conversion to a full size bed for the next step.
What color is the crib?  Call at 770-974-8895 if we can help with your toddler rail.
Sep 10, 2009 | DaVinci Emily Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Converting to toddler bed
yes you need to get the conversion rail. I'm looking for one if anyone can find one. I can't find a number for the manufacturer and the store I bought it from doesn't carry it anymore.
Dec 02, 2006 | Childesigns Carrollton Crib
Childesigns Hadley Crib 64-715 Logo
113 people viewed this question
Top Childesigns Baby Gear Experts
Jaime Hernandez
john h
ray gallant
Are you a Childesigns Baby Gear Expert? Answer questions, earn points and help others
