Question about GE PSS26MGPWW Side by Side Refrigerator
GE PSS26MGPWW Refrigerator set at "2" and food still freezes. Freezer section set at "7" is there a correlation?
    Scholar:
  • 57 Answers
Yes the refrigerator knob is just a damper between the freezer and the refrigerator. All the heat removal is done in the freezer section. it just dumps air through to the refrigerator. So drop the thermostat down to about 5 and try that. If food is still freezing
drop the thermostat a little more. If food continues to freeze then your thermostat could be bad. Not sensing temp properly and allowing the refrigeration system to run to long.
Hope this helps
Posted on May 23, 2008
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Not cooling 1/2 the refrigerator and freezer
If the lower section of the freezer is whats freezing and not the upper portion, or fresh food section,what you need to check is the fan in the freezer to see if its running to circulate the cold air
Gene
Aug 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator inside not getting cold enough. A GE refrigerator side by side.
If it is just the fresh food section and not the freezer. Check out this link to see a GE condenser problem. Make sure to clean that condenser once a year. In most cases when the damper assembly flapper door goes bad in the fresh food section, the fresh food side will start to freeze your food. The next thing I would check is what John is talking about. Pull the freezer back panel off to see if your evaporator coil is frost over. When this happens it will restrict air into the fresh food side(refrigerator side). Click Here to see what a defrost problem looks like.
Jun 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
http://www.partselect.com/PS303781-GE-WR51X10055-Defrost-Heater-Bracket-Assembly.htm?SourceCode=1&ModelNum=HSM25GFRASA
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
GE PSS26MGPWW Side by Side Refrigerator Logo
148 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
