Question about Vicks Warm Mist V745A 1 Gallon Humidifier
Cleaning How do I clean this vick's warm mist humidifier?
  • 5 more comments
  • Anonymous Oct 05, 2008
    How do you clean. I have this flakey brown builup in the humidifier
  • Anonymous Nov 09, 2008
    Me too!
  • Anonymous Dec 01, 2008
    Me three!
  • Anonymous Dec 04, 2008
    help please
  • madatvicks Dec 23, 2008
    How do I get the white build up off of the heating element?  Did vicks think of this when designing it?  The inhalant over fills from the steam and gets onto the element.  It WONT come off!
  • Anonymous Feb 24, 2009
    What about the Water Tank itself. Does the whole white lid come off? I can't seem to get it off and I don't want to break it. and there's no way I can fit anything thru the cap to try and clean the mineral buildup off the tank. It used to be so pretty and clear.
  • Anonymous Apr 18, 2009
    why can't vicks be more responsible and help us fix this, I have the same problem.  bad company!
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
Posted on Jan 18, 2009
You have to scrap it off and work at it if its real bad , I think the reason is because we are using tap water we should be using bottled purified water.
Posted on Jan 11, 2009
  • ronjac41 Apr 19, 2011
    so now i get it. bottle water is the solution! thank you kindly, ron
Vicks warm air humidifier replacement part
Does this help you? http://www.appliancefactoryparts.com/humidifiers/vicks/v5100ns.html
My OX husband trod upon his new humidifier LOL...broke the tank and I cannot stop leaking. Anyone have a site where I can buy just a Vicks tank?
Feb 18, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
I used to see mist coming out of the humidifer. Just set up for this year, changed the filter, etc. and there's no mist coming out. Is this ok?
No you probably have scale around the heater thus not heating the water warm eneough. The water trough is located in the bottom of the unit and it gets covered with scale you can sometimes crumble it off with your fingers. Sometimes you have to use a cleaner on them too. Me personally on mine I clean it with a flat blade. I have cleaned mine twice this year as I have hard water
Dec 13, 2010 | Vicks Cool Mist V3500 Humidifier
How do I clean this humidifier if it smells a bit like mold?
Mix in with the water a small amount of anti fungi solution specific for humidifiers. You can find these solutions at walmart or target.
Sep 02, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Can you tell me what filter the Vicks Warm Mist V745A 1 Gallon Humidifier takes?
did you figure out the filter? there is a filter there when you take it apart but it doesn't say anything in the manuel about changing a filter. let me know if you figured it out. thanks
Mar 06, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
For a vicks warm mist humidafier can you use the vaposteam liquid everyday
i cant see why not. just make sure you have good ventilation to prevent mildew or mold growth
Nov 11, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks Warm Mist V745A 1 Gallon Humidifier Logo
1,686 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
